Hello all,
Second problem of the day: when I use the r.slope.aspect command the results
appear very linear. I am not the only one to experience this problem as
someone who has worked with the data before generated the same linearized
output. Is this a function of the elevation map? If not how do I correct for
this problem? Thanks again.
Bill Green
wg1938@csc.albany.edu
