Hi Markus,
o.k. but If I want only the unique values?
It's working with r.stats -1 DEM | sort -u
but this is terrible slow. Is there a other possibility to do that?
Dieter
Date sent: Tue, 9 May 2000 11:49:55 +0100
From: Markus Neteler <neteler@geog.uni-hannover.de>
To: DIETER LEHMANN <lehmann@fh-nuertingen.de>
Subject: Re: r.stats (grass5)
Hi Dieter,
On Tue, May 09, 2000 at 11:16:18AM +0200, DIETER LEHMANN wrote:
> Hello,
> short question: how is it possible to get the discret raster-values of a
> map? My map has the following values: 0.2 0.6 0.8...
> r.stats only gives me the ranges.this is quite easy:
r.stats -1 dgm25
177.0060272217
176.5745239258
176.0958557129
174.9282073975
173.8042144775
...or with coordinates:
r.stats -1g dgm25
3571612.5 5765037.5 144.0717010498
3571637.5 5765037.5 144.0996246338
3571662.5 5765037.5 144.0055541992
3571687.5 5765037.5 144.1030426025
3571712.5 5765037.5 144.6298828125
3571737.5 5765037.5 145.0991973877Check for NULL suppresion:
-n Suppress reporting of any NULLs
-N Suppress reporting of NULLs when all values are NULLKind regards
Markus Neteler
