r.surf.contour
I wonder if anyone else is frustrated with this program.
I am running 4.0 on a Sun. FOr a moderate sized cell map
(about 500x500) it is taking 10+ hours to run. And then
it is interpolating in a very un-smooth way, *sometimes*.
ie for some levels it just "steps" down the contour, other times
it makes nice ramps across them.
Any comments?
Simon Cox
As I recall, this program is VERY sensitve to the number and
distribution of cells with elevation values in the input raster
file. I believe the manual says that "the programs running time
will increase exponentially with the distance between the contours".
If you have enough (and I do not know how much is 'enough') memory,
use the -f option with r.surf.contour.
My other suggestion is to possibly use r.surf.idw instead. While
r.surf.idw is also sensitive to the distance between the raster cells
(generated from the contour lines), r.surf.idw allows for the
inclusion of 'spot' elevation values (such as converted from sites)
in order to fill in large open areas between contour lines.
The interpolation procedures between these two programs is different,
so I suggest you check the manual to determine the 'best' program for
your needs. Then there is always s.surf.tps?
Mark Gregory mg@adasn4.agr.okstate.edu
Oklahoma State University (405) 744-6417
Stillwater, OK 74078
In one case, we originally converted some vector contour lines into
raster values and then ran r.surf.contour
