R.watershed has been running since 8:15AM 8/22 (today is 8/26) on the
following dataset (current progress follows):
The output from r.watershed will be divided into watershed
basins. There are two possible methods of tabulating the information:
1) by only including data pertaining to the basin itself, or 2) using
data from the basin, and all basins upstream of it.
Would you like the data organized:
1) Basin only
2) Basin and upstream
3) Both
OR 0) to cancell program
Your choice: 1
OK, seg should start running now using the following form:
/usr3/grass4.0/etc/water/seg el="elevation@PERMANENT" de="lakes@PERMANENT" t=1 ba="basin1" ar="relate1" ac="accum1"
SECTION 1 beginning: Initiating Variables. 5 sections total
segments in row: 167
segments in columns: 165
total segments: 27555
open segments: 213
SECTION 1b (of 5): Determining Offmap Flow. Percent Complete:
SECTION 2: A * Search. Percent complete: 4%
MY QUESTION IS THIS:
DOES IT MAKE SENSE THAT IT TAKES APPROXIMATELY 36 HOURS (SUN IPX) TO
KNOCK OFF EACH PERCENT IN SECTION 2: A + Search?
I really need to get this done, so am extremely hesitant to kill the
job and begin again.
I read your previous message about the comparison with Spearfish...
I don't know how big Spearfish is and don't have immediate access to
it to find out.
Thanks for your reply.
Merlyn Paulson, Prof.
Landscape Sciences & GIS Telephone (303)491-7594
Colorado State University Faxphone (303)491-7745
Fort Collins, Colorado 80523 E-mail larch@lamar.colostate.edu
