r.watershed
I am running GRASS4.0 on a DEC 5100. The watershed of concern is very
large - the elev map is roughly 1700 x 750 cells. In running
r.watershed for basin and stream delineation, I dont have enough memory
to run up front. As a result, the program resorts to swapping to disk.
I managed to free up enough disk space to allow it to do this.
However, after approx 3 days of running, the program is only 11% done
with Section 1b- Determining Offmap flow
SECTION 1b (of 5): Determining Offmap Flow. Percent Complete:
  11%
At this rate, the program might terminate in 2-3 weeks.
I am running using a min. outside sub-basin area of 150 km2. The map
is at roughly 90 meter resolution.
Any suggestions on how to speed this up ? Or, if I rescale the
elevation data to 270 meters ( for example), any ideas on how much
information will be lost ? At what resolution will the delination
algorithm not adequately describe the topography ? Will a 600 X 250
map run significantly faster ? Does anyone have experince with scale
and size in r.watershed ?
I would appreciate any/all input. I will summarize and post if there
is enough feedback.
Dan Epstein
