Hello,
I have a series of floating point rasters which I imported using
r.in.ascii. They display and report their statistics (via r.stats)
properly, however I am unable to use them in an unsupervised classification.
When I run i.cluster the report file states that the mean for each raster
is -129 and the stdev is 0.
The only clue I have that something is wrong is that if I run r.support it
reports that each of these rasters is an empty raster file when i attempt
to edit the header, and if I atempt to update the stats it says "can't
write range file".
I am obviously missing something fundamental here, and I would really
appreciate some help.
TIA
Marc Pelletier
Data Donkey - Geophysical Data Processing, Consulting and Software Development
Creator of the POWER TOOLBOX utilities for OASIS montaj
contact: mailto:marc@datadonkey.com tel (306) 931-6853 or
http://www.datadonkey.com
At 05:31 PM 12 17, 1999 +0000, you wrote:
You see that "G_get_c_raster_row" is used. This indicates (I think so)
that i.cluster only works with integer maps. This means you have
to use either r.mapcalc or r.quant to make integer maps from your float
maps.
Hope this helps
Markus Neteler
Actually Markus, once I got the beta 5 version it works fine on my floating
point rasters but still fails on the integer ones! That's ok because I
really wanted to work with the floating point data.
But my next question is...
Does the clustering and classification implicitly assume that all the data
varies from 0 to 255? I ran i.cluster and i.maxlik on a set of 4 rasters
where one represented magnetic data, which varied from 60000 to 61500
gammas, and the other 3 were radioelement concentrations which varied from
0 to 10,15 and 25. The result was totally overwhelmed by the magnetics. The
K, Ur and Th radioelements are strongly correlated with each other and have
little or no correspondence with the magnetics.
Thanks
Marc Pelletier
