Brian,
It sounds as if your DLG-3 file was unlabeled. Attributes are the
points within a polygon where a number is attached, and it sounds as if you had
an "empty" dlg-3 file to start with. Double-check your source and make sure
the file was labeled. ( The category file (in dig_cats) is the file that gives
a text label to each discrete attribute number.)
Ronald Thomas ^ ront@meeker.cfnr.colostate.edu
Natural Resources Spec. (GIS) ^
Resources Management Division ^ Phone: 303-586-3565 x285
Rocky Mountain National Park ^ 700-323-7285 (FTS)
Estes Park, CO 80517 ^
