Re; awk help
There was a utility which would do exactly this.
On some UNIX systems there was a command "lam" that did a line by line
concatenation of text files. This was very useful so I have carried
around the source code from an old BSD system, as I have moved on, and
installed it locally at each place. I don't know why such a useful tool
was deleted from the system. Any ideas, anyone??
Don't use awk to do this. Use pr:
   pr -m -t -l1 -s' ' file1 file2
This will do what you want, except it adds one line at the end of its output
tht contains a single space. If you want to get rid of this last line
add a sed script to delete lines that have only a single space:
   pr -m -t -l1 -s' ' x y | sed '/^ $/d'
|Could someone with with a greater knowledge of awk than me help
|me out with a short script that will read two floating point
|numbers from two seperate files and write out a single file with
|four values on each line ?
_________________________________
Dr Simon Cox |
Department of Earth Sciences |
Monash University |
Clayton Vic 3168 |
Australia |
Phone (03) 565 5762 |
Fax (03) 565 5062 |
________________________________|
