Marcus
Thanks for the input. I Did a bit more digging. I finally tried to run lock
by itself on a test file, It still had the segmentation fault. My guess is
that this is a library version problem.
I'm running SuSE 6.1 Linux on a twin P2 400 SMP. With beta 4 it had only
one problem starting a monitor, but a patch was posted on the defunct forum.
Now lock is trying to access memory it shouldn't. I tried to hack the startup
script to run without the lockout, but it crashed after the first menu anyway.
Oh well, try, try again. I THEN downloaded beta 6 source and tried to
compile that. After several warnings of duplicate naming - it died at
"undefined reference to __waddbytes". I'll post more on that thread.
Well, there went a 4 day weekend that I was going to devote to
photoanalysis and some coding.
So I removed the files for about the 20TH time and reinstalled beta 4. It
works! If the code did not change, something about the compile must have.
This is a very abbreviated version of my various attempts.
I'm planning to pick up SuSE 6.3 in the hope that it helps. I also have Red
Hat, but haven't loaded GRASS on that machine yet. With luck, I'll have some
others running soon.At this pace of change, Debian and its getupdate command
is getting to look very attractive.
AAAaahhhhh.... life at the bleeding edge, isn't it wonderful!
Thanks again
Jim
===== Original Message From Markus Neteler <neteler@geog.uni-hannover.de>
Hi Jim, hi Chris,
what operating system you are using? I guess it is Linux. A current
version?
> I've had GRASS5beta4 running since October, I was hesitant to touch it
but
> yesterday I uninstalled it and installed beta5. When I tried to run it
and
> got:
> GIS.sh line 23: 1308 Segmentation Fault $ETC/lock $lockfile$$
> Unable to properly access /home/nydir/.gislock5
> Jim[...]
Actually I have never seen this error (and working here at university
with several *different* Linux PCs). I need more information about
your systems.FYI I got the same thing, did the same things, etc. It seems that a bit
of housekeeping is needed in upgrading versions - not so bad, if one knows
about it, but annoying otherwise.
Adios,
ChrisOf course this is not intended
As "lock" is unchanged since September 1999
-rw-r--r-- neteler/user 105 1999-07-22 21:30
grass5.0beta/src/libes/lock/Gmakefile
-rw-r--r-- neteler/user 2867 1999-09-16 11:41
grass5.0beta/src/libes/lock/lock.c
-rw-r--r-- neteler/user 372 1999-09-16 11:41
grass5.0beta/src/libes/lock/try.c
-rw-r--r-- neteler/user 189 1999-09-16 11:41
grass5.0beta/src/libes/lock/unlock.c
it is surprising that the software behaves differently between beta4 and
beta5. Perhaps you changed your system somehow?If you send further information, we will fix the problem! Others having
this problem as well may join the discussion (here or personally)!Kind regards
Markus Neteler
