RE: Beta 5 and its lockfile
Eric,
    Thanks, but I tried that, along with running it as root. The lock command
was crashing even when tested in isolation. After getting corrupted HTTP
downloads of binaries and source from Bayor, I used FTP for the binary and had
then this problem. On the chance that it was another download problem, I did
another download from Hannover. Same problem.
  If it is working for you, what kernel and glibc versions are you running?
  I apparently still have libc5.on the 2.2.7 kernel. Time to update and or
compile.
                              Thanks again
                               Jim
===== Original Message From "Eric G . Miller" <egm2@jps.net> =====
Awhile back, I downloaded a binary tarball that unpacked with all kinds
of funky user/group permissions. I think I got it from baylor. Anyway,
distribution tarballs shouldn't preserve owner/group (as this one did)
and may be the source of your problem? Anyway, "chown -R root.staff
/usr/local/grass5.0beta5" should fix it (substitute appropriate
ownership for your setup).
| Eric G. Miller egm2@jps.net |
| GnuPG public key: http://www.jps.net/egm2/gpg.asc |
On Wed, Jan 19, 2000 at 11:27:23PM -0500, jbrowne wrote:
Eric,
compile.
I'm using Debian's unreleased Potato distribution with kernel 2.2.14,
glibc2.1.2 (libc6). Beta5 compiled flawlessly ( a few warnings about
casts) using gcc-2.95. Only thing I've yet to get working is NVIZ2.2.
Seems to be real picky about your Tcl/Tk installation. I get errors
about undefined reference to Tcl_Panic. Haven't been using it
extensively, so I can't comment on undiscovered bugs.
Hi again,
> compile.
Aha! This was the message clearing the problem!!
As you use libc5 you cannot use the precompiled GRASS binaries.
All Linux binaries are based on libc6.
Solution: Either upgrade you system to libc6
          or compile the GRASS locally.
Regards
Markus Neteler
