Hi!
On Mar 24, 4:04pm, Peizhong Wu wrote:
> Subject: Compile problem from a beginner.
[skip]
The problem is that the lists/GRASS file has lines that are commented out and
the GISGEN shell script (basically) does not like them. The *.pre1 files
however will compile all the code in the $GIS/src, $GIS/src.alpha, and
$GIS/src/xgrass directories. As stated above, the xgrass code does not need to
be compiled for GRASS to work. However, if you do want to compile xgrass, you
should note that it will not compile with Motif 2.0 or above.
I want to compile xgrass. With which version of Motif it will compile ?
What you can say about lesstif 0.77 ? I tried to compile xgrass with it,
but without success.
Felix.
