RE: dted0 import
Just wanted to import DTED0 elevation data.
Next question: How to extract information about what is in the file.
(I guess it is in the header) and how to skip that header. :slight_smile:
http://www.ccg.nrcan.gc.ca/ext/html/english/products/cded/cdedspec.pdf
Although this document describes the Canadian version of dted, the
differences between the specs are described, so it may help you anyway.
Physical file description begins on page 5. I used to have the dted spec
doc (~20 pages). If the cded specs don't help, I'll see if I can
resurrect it.
-matt
But it looks like GTOPO30 is more up to date anyway? :slight_smile:
doc (~20 pages).
To all interested in the specs:
   Pointers can be found at
http://164.214.2.59/geospatial/products/DTED/faq.html
I got 89020A_DTED.pdf from the nima website under (Military)
Published Standards.
  Bernhard
Research Assistant, Geog Dept UM-Milwaukee, USA. (www.uwm.edu/~bernhard)
Free Software Projects and Consulting (intevation.net)
