RE: [Geonetwork-devel] Validation of XML against ISO 19139 XSDs and other ISO 19115 rules
Hi Jeroen,
Please see my comments below:
Thanks.
John
-----Original Message-----
From: Jeroen Ticheler [mailto:Jeroen.Ticheler@anonymised.com]
Sent: Tuesday, 23 May 2006 8:41 PM
To: Hockaday John
Cc: geonetwork-devel@lists.sourceforge.net
Subject: Re: [Geonetwork-devel] Validation of XML against ISO
Hi John,
Another reply :slight_smile:
On May 23, 2006, at 8:30 AM, John.Hockaday@anonymised.com wrote:
> Hi Jeroen,
> I forgot to reply to this email. I have been so excited
that you are
> considered my suggested user requirements. ;--)
Good, I like happy people! :slight_smile:
Working together is much more fun than working against each other. ;--)
> I'm not 100% sure of what you are suggesting in your email but I
> think that
> there was a similar discussion on the
metadata@anonymised.com
> list. I
> believe that the identification of when an XML metadata record was
> last
> updated can be gained from the systems date/time stamp on the XML
> file. For
> example, if the XML documents are in a web accessible
folder then the
> "modified time" from the HTML document headers can be used to
> identify the
> time the file was last modified.
Good idea, not sure if we also provide that info in the header.
Andrea would know.
I think that all HTTP accesses to files allow the 'modified time' parameter
to be determined. I do this using PERL. Surely someone has done this with
Java? ;--)
> If the XML documents are available via a RDBMS one can use
a column to
> identify when the XML record was last updated. This seems to be
> what Andrea
> is referring to in her email response to your question. It seems
> that the
> RDBMS field "lastChangeDate" could be used to identify this.
Indeed that was what he (! :wink: ) suggested.
Sorry Andrea for getting assuming you were female. The most common use of
the name "Andrea" is for females in Australia. It must be a cultural thing.
Sorry! Am I forgiven? ;--)
> If you are harvesting using z3950 then this may be a problem. I
> don't think
> that there is an option to identify when the record was
last updated.
> In summary, I think that it is part of the harvesting process that
> will
> identify when an XML record was last modified, not part of the XML
> record's
> content itself.
Yes, correct. Harvesting is not the only place that needs a precise
date, but it seems the above covers all options.
Glad to be helpful. ;--)
Ciao,
Jeroen
> I hope that this helps.
> John
> From: geonetwork-devel-admin@lists.sourceforge.net
> [mailto:geonetwork-devel-admin@lists.sourceforge.net] On Behalf Of
> Jeroen
> Ticheler
> Sent: Saturday, 20 May 2006 12:47 AM
> To: Geonetwork-devel Geonetwork-devel
ISO 19139
> XSDs and
> John and Andrea,
> Just one more comment on the point below. I have been looking into
> this not
> so long ago when we were adding convenience calendars to the
> editor. John,
> you are right about the format of that field. However, there is a
> problematic
> issue for which we do not have an answer here and that
causes us to
> actually
> fill out the field as if it were a DateTime:
> To know when a metadata has been updated, it is not enough to know
> the day.
> For many cases you really need to know exactly when the update
> occurred. For
> instance, when we compare two metadata while harvesting from a
> system, we
> have to know exactly when that metadata was updated last. The same
> is true
> for trivial functions like: what metadata records have a creation
> date and
> dateStamp that only differ by e.g. 1 minute? We can use this to
> retrieve
> metadata records that were added, but than not updated/ edited
> online by a
> user and that may therefor be empty left over records that
an admin
> can clean
> up.
> Any suggestions on this are very welcome!
> Ciao,
> Jeroen
> On May 19, 2006, at 4:31 PM, Andrea Carboni wrote:
> 2. The domain for the "dateStamp" element is "Date". "Date" is an
> ISO 8601
> date format not an ISO 8601 DateTime format. GeoNetwork prompts a
> dateTime
> format in the content of the "dateStamp" element. It should be a
> "Date"
> format. For example, yyyy-mm-dd, yyyymmdd, yyyy-mm, yyyy or yy
> (for the
> century although this is not available in the W3C XML Schema
> implementation)
> not yyyy-mm-ddThh:mm:ss. DateTime formats should also include the
> time zone
> eg. yyyy-mm-ddThh:MM:ss+Z so that local times can be used rather
> than GMT.
> Ok, we can fix it.
