Hi!
You can set ArcCatalog to generate metadata in ISO19115 format in the ArcGatalog preferences.
Version 2 of GeoNetwork allows you to import metadata XML files that were generated by an external system. The XML is then transformed through an XSLT into the GeoNetwork catalog. One of the current XSLT's that is available is the one that allows ArcCatalog XML to be transformed. I'm sure it needs more testing, but we have used it successfully ourselves.
Feedback is very welcome!
Jeroen
On 8 Jun 2005, at 10:05, francisco.manas@...12... wrote:
I´m new to Geonetwork, and I would like to know if there is a way of using
ArcCatalog's generated XMLs with the application.
The problem is that ArcCatalog doesn´t use ISO 19115.I tried to change the dtd but it didn´t work...
Thanks in advance.
***********Internet Email Confidentiality Footer*************
This email and any files transmitted with it are confidential and intended
solely for the use of the organization or individual to whom they are
addressed. It is expressly forbidden to retransmit or copy email and/or
this attached files without our permission . If you are not the
addressee indicated in this message (or responsible for delivery of the
message to such person), you may not copy or deliver this message
to anyone. In such case, you should destroy this message and kindly
notify the sender by reply email. Please advise immediately if you or
your employer does not consent to Internet email for messages of this
kind. Opinions, conclusions and other information in this message that
do not relate to the official business of my firm shall be understood as
neither given nor endorsed by it.-------------------------------------------------------
This SF.Net email is sponsored by: NEC IT Guy Games. How far can you shotput
a projector? How fast can you ride your desk chair down the office luge track?
If you want to score the big prize, get to know the little guy.
Play to win an NEC 61" plasma display: http://www.necitguy.com/?r
GeoNetwork-users mailing list
