RE: [Geoserver-devel] ArcSDE - please help
maybe it's just a case problem. Try asking for a featuretype name with
exactly the same case as it appears in the list of feature types for the
given datastore in the gui application.
If this doesn't work, please send me some more info about your problem. A
stack trace could be helpfull.
Be sure to specify the full qualified name of your feature type on your WMS
or WFS request, for example:
http://host/geoserver/wms/GetMap?LAYERS=SDE.SDE.LAYER_NAME1,SDE.SDE.LAYER_NA
ME2&WIDTH=....
There is a jira task to allow for non full qualified names to be specified
as well as to leave the "instance" parameter blank and use the default sde
database for the given connection. Actually if you do not specify the
instance name the datastore will say this parameter is mandatory. I just
figured out it is not, hope to resolve it as soon as possible.
Please continue sending feedback about your use of ArcSDEDataStore, since it
is the only way I could ensure it works in ohter environments than my own
desk :slight_smile:
best regards,
Gabriel Roldán
-----Mensaje original-----
De: Juan Marín Otero [mailto:jmo@anonymised.com]
Enviado el: jueves, 29 de abril de 2004 8:06
Para: geoserver-devel@lists.sourceforge.net
Asunto: [Geoserver-devel] ArcSDE - please help
I downloaded geoserver rc1.2, and it looks very promising. Web interface
works just fine under Tomcat 5.0.19, I can add ArcSDE datastore and
featureTypes just fine. The problem is that even though my ArcSDE layers
show up in the Capabilities document (and information about them seems
correct), when I try a getFeature (WFS) or getMap (WMS) I get a "no such
layer found in this server" exception. I have tried to put the instance
name before the table name as suggested by the documentation (info.xml
file, by hand), but this makes the layer disappear in the Capabilities
document.
I have set up the parameters for the DataStore correctly, since those same
parameters are used in other applications (ArcGIS, custom apps.) and they
work fine.
I am quite confused, some help might be very appreciated.
Thank you very much,
Juan Marín Otero
TRAGSATEC S.A.
Departamento de Cartografía
Tlf. 91 322 64 98
Este correo es sólo informativo y por lo tanto no supone obligación
contractual para TRAGSATEC ni para las sociedades a ella vinculadas. La
información incluida en el presente correo electrónico es CONFIDENCIAL,
siendo para el uso exclusivo del destinatario arriba mencionado. Si usted
lee este mensaje y no es el destinatario señalado, el empleado o el agente
responsable de entregar el mensaje al destinatario, o ha recibido esta
comunicación por error, le informamos que está totalmente prohibido
cualquier almacenamiento, divulgación, distribución o reproducción de esta
comunicación y de los archivos que pueda contener. Le rogamos que nos lo
notifique, devuelva el original al emisor del correo y destruya el mensaje.
El correo electrónico vía Internet no permite asegurar la confidencialidad
de los mensajes que se transmiten, ni su integridad o correcta recepción.
TRAGSATEC no asume responsabilidad por estas circunstancias. Si el
destinatario de este mensaje no consintiera la utilización del correo
electrónico vía Internet y la grabación de los mensajes, rogamos lo ponga
en nuestro conocimiento de forma inmediata.
This SF.Net email is sponsored by: Oracle 10g
Get certified on the hottest thing ever to hit the market... Oracle 10g.
Take an Oracle 10g class now, and we'll give you the exam FREE.
http://ads.osdn.com/?ad_id149&alloc_id66&op=click
Geoserver-devel mailing list
