Thanks, for all answer, i needed this help
----------- Mensaje Original --------------
De: Chris Holmes [cholmes@anonymised.com]
Para: Paul Hasenohr [paul.hasenohr@anonymised.com]
Cc: geoserver-devel@lists.sourceforge.net
[geoserver-devel@lists.sourceforge.net]
Asunto: RE: [Geoserver-devel] Basic WFS or Transaction WFS
Fecha: 28/03/2003 11:55:25
Mensaje:
Yes, we are definitely working on implementing full locking, as
Transactions need locking to be secure. We're going to try to get that in
the release following the april 11th release. It might not be super
efficient at first, but we do want to get fully spec compliant soon.
Good luck with the installs,
Chris
On Fri, 28 Mar 2003, Paul Hasenohr wrote:
Thank you very much for your answer. It sounds very nice.
I think I'll wait until April 11th for implementing it.
Before installing Geoserver, I have also to install Postgresql/Postgis,
Mapserver and all the needed libraries as I start on "blank" servers.
Do you plan to implement the full LockFeature operations in a further
version ?Thanks
Paul-----Original Message-----
[mailto:geoserver-devel-admin@lists.sourceforge.net] On Behalf Of Chris
Holmes
Sent: vendredi 28 mars 2003 16:28
To: Paul Hasenohr
Subject: Re: [Geoserver-devel] Basic WFS or Transaction WFSGeoServer is a "Transaction WFS". Transactional support was added a few
months ago, and should be pretty solid, though it is still in beta, and
could use a few more beta testers. The optional LockFeature operations
are not fully implemented (currently only does full featureType locking,
can not handle filters, and it's only in cvs, not in the downloadable
version), but they are not required to be a Transaction WFS. The
Geoserver WFS server should suit your needs for the vector part of the
project, if you're willing to get your hands dirty for a little final
beta testing, or if you can wait a few months for the fully tested and
certified 1.0 release. I'm going to try to put out the next release out
by april 11th, which will attempt to hit full 1.0 spec compliance (this
is _not_ the 1.0 release, we need more testing for that) on all the
basic and transactional operations. Most of the code for that release
is already in cvs, so if you want to check it out from there you'll get
the latest version. I just need to write unit tests for the latest
stuff and re-write some of the documentation. I just added support for
multiple namespaces, which changes the configuration (current users of
geoserver should be fine, as it's all backwards compatible). And then
of course I need to test everything again before putting it out.Also, if you're working with the latest download, note that you probably
will run into a disappointing bug that you run into right away, when you
do a the first GetCapabilities from a browser you will probably get an
exception. But I think it should work if you specify the version:
http://localhost:8081/GetCapabilities?version=1.0.0 . Yes, this bug is
fixed on cvs and in the next version.Hope this helps,
Chris
> Hi All,
> I am wondering if Geoserver is a "Basic WFS" or a "Transaction WFS"
> according to the definition available in the document entitled "Web
> Feature Service Implementation Specification"
> (http://www.opengis.org/techno/specs/02-058.pdf page 3). I need to get> vector and raster data from a server, sometimes modify it on the WFS
> client (update or adding of new features) and send it back to the WFS
> server. Can Geoserver suit my needs for the vector part of my project
> Thanks in advance,
> Best regards,
> Paul Hasenohr
> Paul HASENOHR
> EC - Joint Research Centre
> IPSC - MARS, TP 266, 21020 ISPRA (VA), ITALIA
> Direct : +39 0332 78 62 22
> Fax : + 39 0 332 78 51 62 - Web site: http://mars.jrc.it
> <http://mars.jrc.it/>
This SF.net email is sponsored by:
The Definitive IT and Networking Event. Be There!
NetWorld+Interop Las Vegas 2003 -- Register today!
http://ads.sourceforge.net/cgi-bin/redirect.pl?keyn0001en
Geoserver-devel mailing list Geoserver-devel@lists.sourceforge.net
Bladimir Moreno
