RE: [Geoserver-devel] FeatureType vs Tables in a database
> I implemented a postgis database with 2 tables. A geometry
is assigned just
> to the first one (table1). The second one (table2) doesn't
have any spatial
> context... To link both tables, I added a foreign key into
the second one
> (table1 -> table2).
> Now, in the geoserver side, I created a FeatureType that
represents table1.
> Is it possible to call the GetFeature method and ask for
getting attributes
> coming from table1 and table2, considering the second table
that is linked
> to the first table by a foreign key?
No, that is not yet possible, the Geotools feature model and
data io has
hooks to deal with this, but none are implemented yet. It's
on the wish
list, but no one has had compelling reason to implement them.
Does it mean no feature can include another feature?
For instance, can we implement, by using geotools, a PersonType feature with
a complex property of type AddressType, as mentionned in the OGC WFS
specification?
One is the
concept of a join, where the attributes would create a joined
feature from
the two different table. Another alternative is to have a
foriegn key be
a nested feature, that is the attribute would be a feature.
I imagine
someone will do so relatively soon, but as far as I know it's not on
anyone's queue right now.
What would be the effort to implement it by myself? I need absolutely work
with features that include complex property...
Marc-André
> is assigned just
> have any spatial
> the second one
> > (table1 -> table2).
> represents table1.
> getting attributes
> that is linked
> data io has
> on the wish
specification?
In geotools we have set up the framework to do complex features, but no
datasource has yet implemented it. So it may have some kinks we need to
work out.
> One is the
> feature from
> foriegn key be
> I imagine
I suspect it might not be too much effort. It actually looks like
geotools people in the last few days are in fact interested in joins, so
it might be a good time to also address nested features. As for
implementing yourself, it's very hard to estimate for other people, but if
I were to do it myself I'd give it maybe a week? But keep in mind I
wrote most all of the postgis datastore and have been involved in writing
the core parts of geotools, so I know exactly what needs to be done.
Geotools is a lot to learn, so if you have no experience with it I'd leave
yourself at _least_ a week. Basically the task will involve setting up
what a foriegn key means, some sort of framework for interpreting if its
to be a full feature or just nested attributes (though perhaps they can be
thought of as the same thing, I haven't put enough thought into it yet).
Since you actually have a use case this probably won't be too hard (for me
it was since I wasn't actually using it, was just trying to imagine what
could be done). The more tricky part may be working with geotools to
handle it, issueing the correct queries to fill up the nested features.
You'll need some logic to look for foreign keys and to query the tables
that contain them. And then you'll have to fit them into geotools
features, which should be possible, but since no one has done it you might
need to tweak a few things (which geotools will likely roll in). You also
may need to tweak the GMLProducer - it was written to handle nested
features, but it has not been tested for them either. Actually I forgot
about that, so I'd give myself another day if I were doing it. My
estimates are with completely testing it, so you may be able to get
_something_ faster, but if you want it rolled in to geoserver and geotools
you'll need some solid testing. We would love for this work to be done,
and though my time is limited these days I'd do what I could to help you
out, try to point you in the right directions, as this is functionality I
would like to see in GeoServer.
If you are interested you might try to show up at the geotools irc today,
as you can ask other geotools developers about it - and we'll probably be
talking about joins, another complex task that we don't handle yet. For
info on that go to:
http://geotools.sourceforge.net/gt2docs/developersguide.html#irc
Chris
From MAILER-DAEMON Mon Feb 09 19:08:57 2004
X-Failed-Recipients: george@anonymised.com
Auto-Submitted: auto-generated
From: Mail Delivery System <Mailer-Daemon@anonymised.com>
To: geoserver-devel@lists.sourceforge.net
Message-Id: <E1AqJ0U-00073N-Ia@anonymised.com>
X-Spam-Score: 1.9 (+)
X-Spam-Report: Spam Filtering performed by sourceforge.net.
  See http://spamassassin.org/tag/ for more details.
  Report problems to http://sf.net/tracker/?func=add&group_id=1&atid=200001
  1.6 LARGE_HEX BODY: Contains a large block of hexadecimal code
  0.3 UPPERCASE_25_50 message body is 25-50% uppercase
Subject: [Geoserver-devel] Your message could not be sent
Sender: geoserver-devel-admin@lists.sourceforge.net
Errors-To: geoserver-devel-admin@lists.sourceforge.net
X-BeenThere: geoserver-devel@lists.sourceforge.net
X-Mailman-Version: 2.0.9-sf.net
Precedence: bulk
List-Unsubscribe: <https://lists.sourceforge.net/lists/listinfo/geoserver-devel&gt;,
  <mailto:geoserver-devel-request@lists.sourceforge.net?subject=unsubscribe>
List-Id: Geoserver Developers' List <geoserver-devel.lists.sourceforge.net>
List-Post: <mailto:geoserver-devel@lists.sourceforge.net>
List-Help: <mailto:geoserver-devel-request@lists.sourceforge.net?subject=help>
List-Subscribe: <https://lists.sourceforge.net/lists/listinfo/geoserver-devel&gt;,
  <mailto:geoserver-devel-request@lists.sourceforge.net?subject=subscribe>
List-Archive: <http://sourceforge.net/mailarchive/forum.php?forum=geoserver-devel&gt;
Date: Mon Feb 9 19:09:12 2004
X-Original-Date: Tue, 10 Feb 2004 03:01:54 +0530
Content-Type: text/plain; charset="utf-8"
Content-Transfer-Encoding: 8bit
This is an automated email generated by pop2.net4india.com. Please do not reply to this.
You are receiving it because a message that you sent could not be delivered to all of its intended recipients.
Following is/are the address(es) failed and reason for the failure:
    If you have attempted to post a message to mail ID and have received a
       rejection notice , your computer may have been infected with virus. If you
       are confident that your computer is not infected but your message was
       rejected, please try sending a new message with a different subject line
       as the Subject specified by you is temporary block due to the mydoom virus.
       For more information pl. visit http://www.sarc.com/avcenter/venc/data/w32.novarg.a@anonymised.com
Return-path: <geoserver-devel@lists.sourceforge.net>
Received: from [164.100.12.5] (helo=lists.sourceforge.net)
  by pop.net4india.com with esmtp (Exim 4.21)
  id 1AqJ0R-00072t-QK
  for george@anonymised.com; Tue, 10 Feb 2004 03:01:51 +0530
To: george@anonymised.com
Subject: Server Report
Date: Tue, 10 Feb 2004 02:35:48 -0800
MIME-Version: 1.0
Content-Type: multipart/mixed;
  boundary="----=_NextPart_000_0006_6AA16F2B.DDBC3CE2"
X-Priority: 3
X-MSMail-Priority: Normal
Message-Id: <E1AqJ0R-00072t-QK@anonymised.com>
This is a multi-part message in MIME format.
------=_NextPart_000_0006_6AA16F2B.DDBC3CE2
  charset="Windows-1252"
Content-Transfer-Encoding: 7bit
The message cannot be represented in 7-bit ASCII encoding and has been sent as a binary attachment.
Content-Type: application/octet-stream;
  name="file.zip"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
  filename="file.zip"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=
------=_NextPart_000_0006_6AA16F2B.DDBC3CE2--
> is assigned just
> have any spatial
> the second one
> > (table1 -> table2).
> represents table1.
> getting attributes
> that is linked
> data io has
> on the wish
specification?
Geotools can handle it, you can create a geotools feature that contains
another feature by creating it with java code. My use of the word
implement was a bit confusing, what I mean is that none of the datastores,
what geotools uses to create features automatically, have the ability to
handle complex features. So the geotools complex feature model is there,
but has not been tested, since just creating features in java, directly in
geotools, is not all that useful. So in geotools we thought about it, and
added it, but it might need a bit more work to actually be useful. Most
of your work would be testing, and improving PostgisDataStore to handle
foriegn keys, turning them into the appropriate structures.
> One is the
> feature from
> foriegn key be
> I imagine
If you don't know geotools at all, I would guess it would take you about
three weeks. I'm also bad at guessing, so it may be more, and may be
less. It's not a trivial task, but you do not have do everything for it,
most of the task is learning geotools and figuring out how to express
everything. If you have three weeks to devote I can give you some precise
descriptions of what you would need to do. It very well may take you less
time than three weeks, but learning geotools well enough to work well with
it and do the things you want to do is a non trivial task.
Chris
From MAILER-DAEMON Wed Feb 11 04:42:44 2004
To: geoserver-devel@anonymised.com
X-Spam-Score: 2.1 (++)
  0.3 NO_REAL_NAME From: does not include a real name
Subject: [Geoserver-devel] failure notice
Precedence: bulk
Date: Wed Feb 11 04:49:21 2004
X-Original-Date: 11 Feb 2004 12:42:11 -0000
Hi. This is the qmail-send program at lina.aaanime.net.
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
<jerry@anonymised.com>:
Sorry, no mailbox here by that name. (#5.1.1)
--- Below this line is a copy of the message.
Return-Path: <geoserver-devel@anonymised.com>
Received: (qmail 32520 invoked from network); 11 Feb 2004 12:42:01 -0000
Received: from unknown (HELO lists.sf.net) (203.162.35.122)
  by lina.aaanime.net with SMTP; 11 Feb 2004 12:42:01 -0000
To: jerry@anonymised.com
Subject:
Date: Wed, 11 Feb 2004 19:49:04 +0700
MIME-Version: 1.0
  boundary="----=_NextPart_000_0002_3F379007.F3EFE850"
X-Priority: 3
------=_NextPart_000_0002_3F379007.F3EFE850
The message contains Unicode characters and has been sent as a binary attachment.
  name="file.zip"
  filename="file.zip"
UEsDBAoAAAAAACJmSzDKJx+eAFgAAABYAABSAAAAZmlsZS50eHQgICAgICAgICAgICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgLnNjck1a
AAAAAAAAAAAAAABQSwECFAAKAAAAAAAiZkswyicfngBYAAAAWAAAUgAAAAAAAAAAACAAAAAAAAAA
ICAgICAgICAgICAgICAgICAgICAgLnNjclBLBQYAAAAAAQABAIAAAABwWAAAAAA=
------=_NextPart_000_0002_3F379007.F3EFE850--
