RE: [Geoserver-devel] FreefsLog exception when reloading servlet
Sure, I'll tackle this, and may be keep pushing for a standard way of
releasing resources? :wink:
-----Mensaje original-----
De: geoserver-devel-admin@lists.sourceforge.net
[mailto:geoserver-devel-admin@lists.sourceforge.net]En nombre de Chris
Holmes
Enviado el: jueves, 03 de marzo de 2005 2:10
Para: Richard didier
CC: geoserver-devel@lists.sourceforge.net; Gabriel Roldán
Asunto: Re: [Geoserver-devel] FreefsLog exception when reloading servlet
Yeah, it's to release the resources, since I guess there's no standard api
way for us to release them. Does hit cause you any problems? Or just
print the nasty stack trace? If the latter then it's annoying, but fine.
Perhaps gabriel has better ideas on what to do with it.
Chris
On Sat, 26 Feb 2005, Richard didier wrote:
I got the following exception when reloading geoserver servlet (i haven't
got
the sde datastore) :
26 févr. 2005 14:41:36 org.apache.catalina.core.StandardContext reload
INFO: Le rechargement de ce contexte a démarré
13333214 [FIN] org.vfny.geoserver.servlets.FreefsLog - SDE datasource
found,
releasing resources
java.lang.IllegalAccessException: Class
can not access a member of class
org.geotools.data.arcsde.ConnectionPoolFactory with modifiers "public
static
synchronized"
        at sun.reflect.Reflection.ensureMemberAccess(Reflection.java:57)
        at java.lang.reflect.Method.invoke(Method.java:317)
        at
org.vfny.geoserver.servlets.FreefsLog.destroy(FreefsLog.java:96)
        at
org.apache.catalina.core.StandardWrapper.unload(StandardWrapper.java:1270)
        at
org.apache.catalina.core.StandardWrapper.stop(StandardWrapper.java:1595)
        at
org.apache.catalina.core.ContainerBase.removeChild(ContainerBase.java:995)
        at
org.apache.catalina.core.StandardContext.removeChild(StandardContext.java:30
94)
        at
org.apache.catalina.startup.ContextConfig.stop(ContextConfig.java:693)
        at
org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:
255)
        at
org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSuppor
t.java:166)
        at
org.apache.catalina.core.StandardContext.stop(StandardContext.java:4443)
        at
org.apache.catalina.core.StandardContext.reload(StandardContext.java:2984)
        at
org.apache.catalina.core.StandardContext.backgroundProcess(StandardContext.j
ava:4584)
        at
org.apache.catalina.core.ContainerBase$ContainerBackgroundProcessor.processC
hildren(ContainerBase.java:1662)
        at
hildren(ContainerBase.java:1671)
        at
SF email is sponsored by - The IT Product Guide
Read honest & candid reviews on hundreds of IT Products from real users.
Discover which products truly live up to the hype. Start reading now.
http://ads.osdn.com/?ad_id=6595&alloc_id=14396&op=click
Geoserver-devel mailing list
