thanks a lot for all your support, that's simply great!
Indeed, geoserver works on websphere 5.1 without any problem, I simply deploy the .war.
However I still have a small issue:
when I connect to localhost/geoserver and after login I cannot see any of the menu, I have instead the following message (sorry it is based on WebSphere in french).
[ServletException in:/WEB-INF/pages/actionator.jsp] /WEB-INF/pages/actionator.jsp(34,50) L'attribut .short n'a pas de valeur.'
(translation: the attribute .short has no value)
It is the same for all *tor.jsp pages. Exactly the same problem with Geoserver1.3RC1 or Geoserver 1.2.
Any ideas on this? I search JIRA but could not find any answer.
I have not installed JAI lib so I understand that WMS cannot generate bitmap files but it looks like even in 1.3 (I tried the mapbuilder demo in data/mbdemo/) it does not generate a bitmap image, anything I miss there? Of course I have the GetCapabilities sending back xml file in both WFS and WMS.
Maybe this kind of request should rather go to the user mailing list...sorry for that.
I thought it could be useful for developer also to mention that during the deployment I had this message from WebSphere (although it has nothing to do with the above problem), I am not sure what it means so here are the full code (but it does not seems to be any real issue):
Contenu du fichier was.policy -
// Template policy file for enterprise application.
// Extra permissions can be added if required by the enterprise application.
// NOTE: Syntax errors in the policy files will cause the enterprise application FAIL to start.
// Extreme care should be taken when editing these policy files. It is advised to use
// the policytool provided by the JDK for editing the policy files
// (WAS_HOME/java/jre/bin/policytool).
grant codeBase "file:${application}" {
grant codeBase "file:${jars}" {
grant codeBase "file:${connectorComponent}" {
grant codeBase "file:${webComponent}" {
grant codeBase "file:${ejbComponent}" {
-------- Message d'origine--------
De: Gabriel Roldán [mailto:groldan@anonymised.com]
Date: mar. 14/06/2005 16:19
À: Gerald Estadieu
Cc: Geoserver-devel
Objet: Re: [Geoserver-devel] geoserver in utility
Hi, as the greatest part of your questions was already answered, I'll
try to answer the ones that do not:
- Geoserver on IBM WebSphere
Anybody have an experience to run GeoServer within IBM Websphere? I do
not expect any big issue to deploy the war but if anybody has some
experience on this it will be more than welcome.
Yes, GeoServer works perfectly in Webpshere 5.1+ (since 5.1 is the first
version with a 1.4 JDK)
- Geoserver benchmark
On the long term, our several web applications which can integrate geospatial information will be
accessible by 1.500 users, therefore we were wondering if anybody have any benchmark / info about clustering solution and so on...
Not really, but in the not-so-long term, geoserver will have a much more
scalable architecture. We're just thinking on the alternatives beside a
pure EJB approach. Personally, I wouldn't like to go EJB 2, but EJB 3.0
looks promising.
best regards,
Gabriel.
DISCLAIMER:
The contents of this message is attorney privileged and confidential. The information provided is solely for the use of the individual or entity named above. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this document is strictly prohibited. If you have received this document in error, please send it back to the sender. Any opinions contained in this e-mail, explicit or implied, are solely those of the author and do not necessarily represent those of Companhia de Electricidade de Macau-CEM, S.A.
