correct,
just the INFO-FORMAT parameter should be mandatory.
could you setup a jira task on this and assign it to me?
best regards,
Gabriel.
-----Mensaje original-----
De: geoserver-devel-admin@lists.sourceforge.net
[mailto:geoserver-devel-admin@lists.sourceforge.net]En nombre de Alessio
Fabiani
Enviado el: miércoles, 11 de mayo de 2005 17:48
Para: geoserver-devel@lists.sourceforge.net
Asunto: [Geoserver-devel] GetFeatureInfo
the WMS needs the FORMAT parameter in the GetFeatureInfo request, but
in the OGC specifics seems that this parameter should not be requested
in GetFeatureInfo.
Is it right? In this case the check on this parameter should be removed!!!
This SF.Net email is sponsored by Oracle Space Sweepstakes
Want to be the first software developer in space?
Enter now for the Oracle Space Sweepstakes!
http://ads.osdn.com/?ad_ids93&alloc_id281&op=click
Geoserver-devel mailing list
