just answered withouth seeing your reply Chris.
But yes, the spect says you must copy the originar GetMap parameters, though
FORMAT is meaningless for GetFeatureInfo (though I don't remember right now
if the spec says something specific about this), the point is that FORMAT
has no meaning in a GetFeatureInfo request, this it defines its own
parameter: INFO-FORMAT to specify in which format to response, and it is
indeed defined to avoid conflict with the GetMap FORMAT parameter.
so, we would be do? be strict or not?
open to suggestions.
-----Mensaje original-----
De: geoserver-devel-admin@lists.sourceforge.net
[mailto:geoserver-devel-admin@lists.sourceforge.net]En nombre de Chris
Holmes
Enviado el: miƩrcoles, 11 de mayo de 2005 19:55
Para: Alessio Fabiani
CC: geoserver-devel@lists.sourceforge.net
Asunto: Re: [Geoserver-devel] GetFeatureInfo
No, it's covered in the kvp <map_request_copy> in the GetFeatureInfo
request table (I'm on the 1.1.1 spec, top of page 40):
7.3.3.4 map_request_copy
<map request copy> is not a name/value pair like the other parameters.
Instead, most of the GetMap request parameters that generated the
original map are repeated. Two are omitted because GetFeatureInfo
provides its own values: VERSION and REQUEST. The remainder of the
GetMap request shall be embedded contiguously in the GetFeatureInfo
request.
You have to include all the original params of the GetMap request, and
format is one of them. I know, kinda silly, but I'm pretty sure that's
how it works. I'd be fine with not being super strict on the format,
but I'm not sure of our implementation - if we actually use the format
param on our request - like if it's used to generate the map.
C
Quoting Alessio Fabiani <alessio.fabiani@anonymised.com>:
the WMS needs the FORMAT parameter in the GetFeatureInfo request, but
in the OGC specifics seems that this parameter should not be
requested
in GetFeatureInfo.Is it right? In this case the check on this parameter should be
removed!!!-------------------------------------------------------
This SF.Net email is sponsored by Oracle Space Sweepstakes
Want to be the first software developer in space?
Enter now for the Oracle Space Sweepstakes!
http://ads.osdn.com/?ad_id=7393&alloc_id=16281&op=click
Geoserver-devel mailing list
This mail sent through IMP: https://webmail.limegroup.com/
