Hi Nedjo,
Just letting you and the list know that I finally have Geoclient working
correctly (using the 'capabilities.php' file edit described in my previous
email). It seems to depend on the shapefile I export to mySQL. I've tried
two shapefiles and it works perfectly with one. The second works as well but
any action like zoom in or out is prefaced by this Jscript error message:
'eldnl' is undefined
line: 796, column: 13
Once I o.k. the message, the requested action ensues.
Eamonn
_____________________________________
Éamonn Ó Tuama
Coastal & Marine Resources Centre, UCC
Thanks. The "eldnl" error may result from a problem in the php file
generating the "extended layer description", e.g., incorrect handling of
null values. I'll look into this.
Nedjo
----- Original Message -----
To: <geoserver-devel@lists.sourceforge.net>
Cc: ''Nedjo Rogers ' ' <nedjo@anonymised.com>
Sent: Wednesday, December 11, 2002 3:00 AM
Subject: RE: [Geoserver-devel] getting geoclient to work?
Hi Nedjo,
but
Eamonn
Éamonn Ó Tuama
