The SVGEncoder version I have in my computer has the ability of encoding FID
and any other attribute data
as attributes in the resulting SVG elements for each feature. Althoug I was
very inactive in geoserver for the last
2 months, I think I'll be able of commiting it if you need it.
please all of you excuse my ausence, since some of the discused topics were
directly related to my work in geoserver,
it's just that I was (and still I am) trying to reach a dead line were it
was supposed we were 5 developers and actually we're just 3, so I'm very
bussy with my main project.
regards,
Gabriel Roldán.
----- Original Message -----
To: <geoserver-devel@lists.sourceforge.net>
Sent: Saturday, January 10, 2004 12:01 PM
Subject: RE: [Geoserver-devel] getting image from wms results in error
yes, my province-layer is polygons. with the modified SVGEncoder it works
perfect, thanks for fixing that.
for my purpose it would be nice to still have the fid-attribute from the
gml-output in the svg-output. i will probably modify SVGEncoder a bit.
does
the Feature-class expose this attribute?
<jpp:country fid="country.19260">
<path d="..." id="country.19260" />
jean-pierre
At 19:39 09.01.2004 -0500, you wrote:
>So I spent a bit of time investigating, and it looks like the SVG encoder
>missed a call to encode polygons. I'm having trouble with my SVG
>plug-ins, so I couldn't actually view it, but it now _does_ generate xml
>for the lines. I assume your layer is polygons, or else we've got some
>other problem... I was able to succesfully use a postgis datasource. It
>looks like the class has two ways to encode polygons, if this doesn't
work
>you may try changing line 561 to say writePolyContent( instead of
>writePoly( . So just move this class to
>geoserver/src/org/vfny/geoserver/responses/wms/map/ and rebuild
geoserver,
>and it may fix the problem. Thanks for catching the bug, and let me know
>if this fix works.
>Chris
This SF.net email is sponsored by: Perforce Software.
Perforce is the Fast Software Configuration Management System offering
advanced branching capabilities and atomic changes on 50+ platforms.
Free Eval! http://www.perforce.com/perforce/loadprog.html
Geoserver-devel mailing list
