RE: [Geoserver-devel] GZ GML
IMO stuff like Gzip should be handled at either the HTTP server level, as Paul mentioned, or by using Servlet Filters. This means Geoserver does not have to handle it directly.
There is a good article on Servlet filters for content compression at http://www.onjava.com/pub/a/onjava/2003/11/19/filters.html
Sean
-----Original Message-----
Sent: Wednesday, 10 March 2004 10:43 AM
To: Paul Ramsey
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] GZ GML
> Regarding gzipped GML, should GeoServer do this at all? This is a
> protocol level thing, the client requests compression if
possible and
> the server compresses if able. You could probably make GeoServer do
> compression just be running it behind a web server that supported
> compression, like Apache with mod_deflate enabled. Why add any
> infrastructure at all to GeoServer, it is an HTTP thing.
Well, I think GeoServer should definitely send gzipped gml if
the client specifically requests it (in the getFeature
request), as this is completely in the scope of the spec, to
request different formats. This way clients who don't know
how to ask for the gzipped stuff in the http header can also get it.
As for doing it automatically, I'm a bit ambivalent. On the
one hand I do sorta agree that it's a lower level compression
that geoserver shouldn't do. But on the other hand geoserver
is a server, and one of the main design goals is to make it
really easy to set up while still being very powerful. I
imagine that a number of users who have some data to share
aren't sys admins who are super experienced at compiling
apache with mod_deflate, let alone setting up apache with a
connector to a servlet container (something I've done once or
twice and definitely found it to be a bitch). Most all
installs of geoserver I've seen are run directly from the
servlet container, so from that perspective I think it makes
sense to do it for them if we can, as I don't believe (I
could be wrong here) that tomcat or resin or any of them do
that sort of compression in their built in web servers. So
yeah, the one thing I'm going to insist with Gabriel rolling
it in is that it's absolutely seamless. Gabriel, could you
start it on a branch or give it a config option similar to
the SPEED strategy, so we can test it out before it just
shows up in geoserver code? I think it should maybe wait
until 1.2.1, at least as a default. Make the option
available in 1.2.0 so we can all sanity check it if we want
to. And even in 1.2.1 I think we should put an option in the
services.xml file (and in the ui) for users to turn it on or off.
Chris
> P.
This SF.Net email is sponsored by: IBM Linux Tutorials Free
Linux tutorial presented by Daniel Robbins, President and CEO
of GenToo technologies. Learn everything from fundamentals to
system
administration.http://ads.osdn.com/?ad_id=1470&alloc_id=3638&op=click
Geoserver-devel mailing list
Well, I just committed a refactoring of FeatureTypeResponse to deal with a
new output format: GML2.gz
to do that, I needed to separate the execution of the query from the
response preparation in execute().
The apporach was to leave FeatureResponse deal with the execution and make
delegates for encoding to
the desired output format.
Also added getContentEncoding to Response interface, wich returns null or
the content encoding if there are any. GML2FeatureResponseDelegate returns
"gzip" if outputformat was "GML2.gz". This delegate deals with both GML2 and
GML2.gz formats, but the API now allows to add new encoders for other output
formats by just adding a new encoder (implementation of
FeatureResponseDelegate) in FeatureResponseDelegateFactory.
I have tested it almost extensively and I'm getting the same result as
before the change.
Any feedback will be appreciated.
best regards,
gabriel
----- Original Message -----
From: "Geoghegan, Sean" <Sean.Geoghegan@anonymised.com>
To: "'Chris Holmes'" <cholmes@anonymised.com>; "Paul Ramsey"
<pramsey@anonymised.com>
Cc: <geoserver-devel@lists.sourceforge.net>
Sent: Wednesday, March 10, 2004 4:25 AM
Subject: RE: [Geoserver-devel] GZ GML
Sean
> From: Chris Holmes [mailto:cholmes@anonymised.com]
> To: Paul Ramsey
> possible and
> Chris
> > P.
> system
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Free Linux tutorial presented by Daniel Robbins, President and CEO of
GenToo technologies. Learn everything from fundamentals to system
Hmm.. I really liked the filter idea, having that logic completely
outside of GeoServer. But I do think having the GML2.gz option directly
available to the client is pretty esential, as I don't know that all
clients will know to request it. I've seen other wfs's that make gml2.gz
and gml2.zip available, so I think that's pretty normal to do. And then I
feel like if we've got the logic in geoserver already then we might as
well just do the automatic detection there, or else we'd be replicating
the work of gzipping.
Gabriel, next time you do a change of this sort, that people haven't
necessarily decided on, and that's right before a release, could you put
it on a branch? I think that we should start working on branches for most
any new feature - only bug fixes should routinely go on head. This will
allow us to get releases out more often - after 1.2.0 I'd like to get
minor releases out every 2-4 weeks, for most any little improvement. If
we're always waiting for someone to finish up, and are worried about
testing then that's more difficult to do.
Chris
before the change.
best regards,
gabriel
> Sean
> > To: Paul Ramsey
> > possible and
> > Chris
> > > P.
> > system
> > _______________________________________________
oops! will use branches, sorry
To: "Gabriel Roldán" <gabriel.roldan@anonymised.com>
Cc: "Geoghegan, Sean" <Sean.Geoghegan@anonymised.com>; "Paul Ramsey"
<pramsey@anonymised.com>; <geoserver-devel@lists.sourceforge.net>
Sent: Thursday, March 11, 2004 4:38 AM
Chris
a
make
or
returns
and
output
> before the change.
> best regards,
> gabriel
as
not
> > Sean
> > > To: Paul Ramsey
> > > possible and
do
> > > Chris
> > > > P.
> > > system
The gz stuff looks good, though we might think about changing one thing.
I sorta feel that if the user requests GML2.gz in his request then the
mime type should be .gz (there's a gzip mime type, right?). I don't think
I so much like the behavior of a browser automatically trying to display
it. I sometimes test huge datasets to see how geoserver holds up, and I
always had to use my little java utilities as mozilla trying to display 10
megs of xml does not lead to a happy mozilla. So I was excited that for
big datasets I could just use the gml2.gz - but with the mime type the
same the browser just displays it. If the mime type was gzip I _think_
mozilla would then give me the option to save it... What do others think
about this? It shouldn't be super difficult to change, no?
<anal rant>
Also could you _please_ format your source code to follow the geoserver
conventions? And could you _please_, _please_
do more javadocing? I let you get away with it more the last time, since
you were on super tight deadlines and were working your ass off. Yes, I
know these are both pretty anal requests, but I feel it's really important
for a collaborative project. I definitely had a little trouble figuring
out what was new and what was old in your re-written stuff. There are
definitions for jalopy in the documents section, which will format your
code exactly as we want it. And do you refractions guys have formatting
definitions for eclipse for GeoServer? And my last anal request is no .*
imports. It's much easier to figure out how to find the classes if they
are all laid out at the top. Eclipse will automatically do this for you -
and I'm sure there are other tools. </anal rant>
Chris
> Chris
a
make
or
returns
and
output
> > before the change.
> > best regards,
> > gabriel
as
not
> > > Sean
> > > > To: Paul Ramsey
> > > > possible and
do
> > > > Chris
> > > > > P.
> > > > system
Gabriel: You broke the application.
1 | REQUEST
CUSTOM | A valid document | A NON valid document | AND |
- Mon Mar 15 13:40:52 CST 2004 : Line = 26 Column = 40 Message = {cvc-complex-type.2.4.a: Invalid content starting with element ‘GML2.gz’. One of ‘{“http://www.opengis.net/wfs”:GML3, “http://www.opengis.net/wfs”:GML2-ZIP, “http://www.opengis.net/wfs”:GML3-ZIP, “http://www.opengis.net/wfs”:SHAPE-ZIP, “http://www.opengis.net/wfs”:XML-OS_SVG, “http://www.opengis.net/wfs”:XML-OS_SVG-ZIP, “http://www.opengis.net/wfs”:XML-TIGER_SVG, “http://www.opengis.net/wfs”:XML-TIGER_SVG-ZIP}’ is expected.}
- Mon Mar 15 13:40:52 CST 2004 : Line = 42 Column = 40 Message = {cvc-complex-type.2.4.a: Invalid content starting with element ‘GML2.gz’. One of ‘{“http://www.opengis.net/wfs”:GML3, “http://www.opengis.net/wfs”:GML2-ZIP, “http://www.opengis.net/wfs”:GML3-ZIP, “http://www.opengis.net/wfs”:SHAPE-ZIP, “http://www.opengis.net/wfs”:XML-OS_SVG, “http://www.opengis.net/wfs”:XML-OS_SVG-ZIP, “http://www.opengis.net/wfs”:XML-TIGER_SVG, “http://www.opengis.net/wfs”:XML-TIGER_SVG-ZIP}’ is expected.}
This means that the client performing the request did not request gzip data, got it and could not use it.
David
oh! I very apologize!
but can’t figure out where the problem goes from.
Look:
in GML2FeatureResponseDelegate:
/** will be true if GML2.gz output format was requested */
private boolean compressOutput = false;
/*if compressOutput == true, then “gzip” will be sent as content-encoding http response header, if not,
no response header will be sent at all
public String getContentEncoding() {
return compressOutput ? “gzip” : null;
//here, outputFormat is the format explicitly requested or just “GML2” by default
public void prepare(String outputFormat, GetFeatureResults results)
throws IOException {
//compressOutput will be true only if “GML2.gz” was explicitly requested
this.compressOutput = “GML2.gz”.equalsIgnoreCase(outputFormat);
this.results = results;
So I’m a bit confused about what you’re saying.
Is may be that client taking the output format from the capabilities document and can it being getting confused since both “GML2” and “GML2.gz” are specified in capabilities?
are those results from CITE tests? if not, which client is it?
once again, I’m very sorry about that.
can you keep helping me to resolve it the faster possible?
regards,
gabriel
To: Chris Holmes
Cc: Gabriel Roldán ; geoserver-devel@anonymised.comts.sourceforge.net
Sent: Monday, March 15, 2004 9:58 PM
1 REQUEST
CUSTOM
A valid document A NON valid document AND
David
I'm pretty sure the problem is just the validation of the capabilities
document. GML2.gz is not an expected output format. GML2-ZIP is, so
maybe we can use that? Not sure if gzip counts as zip... That's
probably the easiest fix - the other option is to use a native element,
I'm pretty sure you can for the output format, but I don't know off the
top of my head how you specify it. It looks like we should maybe also
support the GML2-zip, that's pretty easy to do with java right? Just
use the zipoutputstream? It'd be cool to provide the two options.
Also I'd never really seen that list of valid output formats before -
it looks like providing SHAPE-ZIP is common, as well as SVG. Perhaps
we should provide a featureResponse delegate that uses the svg writer?
So you could request svg from wms or wfs?
Chris
Quoting Gabriel Roldán <gabriel.roldan@anonymised.com>:
but can't figure out where the problem goes from.
Look:
    /**if compressOutput == true, then "gzip" will be sent as
    no response header will be sent at all*/
        return compressOutput ? "gzip" : null;
"GML2" by default
results)
        //compressOutput will be true only if "GML2.gz" was
"GML2.gz".equalsIgnoreCase(outputFormat);
So I'm a bit confused about what you're saying.
document and can it being getting confused since both "GML2" and
"GML2.gz" are specified in capabilities?
once again, I'm very sorry about that.
regards,
gabriel
  To: Chris Holmes
  Cc: Gabriel Roldán ; geoserver-devel@lists.sourceforge.net
        1 REQUEST
        CUSTOM A valid document A NON valid document AND a.. Mon Mar
'GML2.gz'. One of '{"http://www.opengis.net/wfs&quot;:GML3,
"http://www.opengis.net/wfs&quot;:GML2\-ZIP,
"http://www.opengis.net/wfs&quot;:GML3\-ZIP,
"http://www.opengis.net/wfs&quot;:SHAPE\-ZIP,
"http://www.opengis.net/wfs&quot;:XML\-OS\_SVG,
"http://www.opengis.net/wfs&quot;:XML\-OS\_SVG\-ZIP,
"http://www.opengis.net/wfs&quot;:XML\-TIGER\_SVG,
"http://www.opengis.net/wfs&quot;:XML\-TIGER\_SVG\-ZIP\}' is expected.}
          b.. Mon Mar 15 13:40:52 CST 2004 : Line = 42 Column = 40
element 'GML2.gz'. One of '{"http://www.opengis.net/wfs&quot;:GML3,
  David
This mail sent through IMP: http://horde.org/imp/
Reopened Geos-113 (getCapabilities). With the result returned it is not posible to generate new sessions for cite tests. We have run the tests on both resin 3.0.4 and tomcat 5.0.19 using windows 2k. We should note that struts requires jsp 2.0 (so tomcat 4.X is out). Basically we cannot test until this works. As a side note, the same 42 tests are failing for cite tests with similar reasons for both web containers (lots of getCapabilities, and had some bad validation tests included in the WAR).
David
Sorry, I can't get the fix in right now, but I don't think it's that hard.
Instead of returning GML.gz return GML2-ZIP. Or return nothing. Log it
as work done on this issue, and leave it open so we can figure out later
if we should use a native elemnt or something. But for now it just needs
to validate so we can have the rest of the tests work.
Chris
David
