Hi Alessio,
what do you mean exactly by "...ingestion engine"
and by "...At the end the user should be able
to manage Geoserver data like a file system directory tree"???
I'm asking this because it sounds like something we may need too,
but maybe I'm misunderstanding...
Regarding Quartz, I'm not a guru about licences, but I think there should be
no problem. GeoServer uses the GPL, so if you develop a new
piece of software that "links" to it, or that cannot exists without it,
that new piece of software must be under the GPL too.
But it's not true the other way around. The licence of Quartz lets you
use it for whatever purpose, even within commercial products, and that
surely doesn't exclude GPL products.
Maybe it's true that if GeoServer won't work anymore without Quartz,
that could be a "contamination" of the GPL, I don't know...
Looking, very briefly, on the Net I found these links:
http://java-source.net/open-source/job-schedulers
Bye
Paolo Rizzi
-----Original Message-----
To: geoserver-devel@lists.sourceforge.net
Sent: 15/07/2005 11.54
Subject: [Geoserver-devel] Ingestion Engine
Hi list,
I'm going to implement an ingestion engine for Geoserver data because
trying to use the actual ingestion system with a large amount of data
is near impossible.
Me and Simone have discussed a lot about it, and finally we have
decided to build something similar to the "Live Deploy" in Tomcat or
JBoss, basically a thread that at certain temporal intervals reads the
file system and checks for changes. At the end the user should be able
to manage Geoserver data like a file system directory tree.
I would like to start building the main thread and I'm evaluating
several solutions. It would be great to use Quartz Scheduler but I
think that it has a License incompatible with the Geoserver one.
Does someone know if there is any other open source scheduler
available on the net?
Any suggestion about this idea will be very appreciated.
Alessio.
SF.Net email is sponsored by: Discover Easy Linux Migration Strategies
from IBM. Find simple to follow Roadmaps, straightforward articles,
informative Webcasts and more! Get everything you need to get up to
speed, fast. http://ads.osdn.com/?ad_idt77&alloc_id492&op=click
Geoserver-devel mailing list
