Hi David,
Thank you so much for the reply.
I tried hitting that way, and the schema can be located.
But I still get the same error.
I copied and pasted the responded xml:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema\-instance">
<soapenv:Body>
<xs:schema targetNamespace="http://www.openplans.org/topp" xmlns:topp="http://www.openplans.org/topp" xmlns:gml="http://www.opengis.net/gml" xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified" version="1.0">
<xs:import namespace="http://www.opengis.net/gml" schemaLocation="http://localhost:7001/geoserver/data/capabilities/gml/2.1.2/feature.xsd"/>
<xs:complexType xmlns:xs="http://www.w3.org/2001/XMLSchema" name="bc_roads_Type">
<xs:complexContent>
<xs:extension base="gml:AbstractFeatureType">
<xs:sequence>
<xs:element name="the_geom" minOccurs="0" nillable="true" type="gml:MultiLineStringPropertyType"/>
<xs:element name="LENGTH" minOccurs="0" nillable="true" type="xs:double"/>
<xs:element name="BTRN_BC_ID" minOccurs="0" nillable="true" type="xs:int"/>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
<xs:element name='bc_roads' type='topp:bc_roads_Type' substitutionGroup='gml:_Feature'/>
</xs:schema>
</soapenv:Body>
</soapenv:Envelope>
best regards,
Sophie
-----Original Message-----
Sent: Wednesday, July 07, 2004 10:22 AM
To: Sophie Wang
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] invalid element error
Hi Sophie,
I think i found a related bug a couple days ago
(http://jira.codehaus.org/browse/GEOS-189). Your parser is really
complaining that it cannot resolve the gml schema location (I think).
Try hitting the url directly inside mozila to ensure the schema location
is valid.
Hope this helps, David
On Wed, 2004-07-07 at 10:11, Sophie Wang wrote:
Lately I am working on the DescribeFeatureType web service. The
client uses the function WFSBasicDescribeFeatureType.I keep getting org.xml.sax.SAXException invalid element, which
complains about "import". "import" is one of the element in the
responded xml:<soapenv:Body>
version="1.0"><xs:import namespace="http://www.opengis.net/gml"
schemaLocation="......
The server runs well. The tcpmon got request and response for
Could anyone throw some light on that?
I would appreciate it very much.Best Regards,
Sophie==========================
Sophie Wang
Software Engineer
Polexis
A SYS Technologies Company
Direct: 858-244-7415
http://www.polexis.com
