RE: [Geoserver-devel] Oracle Support
Did manage to get oracle sort of working yesterday - I think my remaining problems were that I was building the geotools jars from the CVS head. I’ll try a few more things tonight and let you know how I get on. The things I had to do were a bit different from the docs, though.
I don’t have a public facing oracle, but I’ll try to search oracle’s technet site for suitable articles for installing oracle on linux. They are there and they do work, but they can be a pain to find :frowning:
I’ll now take this discussion to the jira issue as requested.
John Grange
Software Team Leader
Tel: +44 (0) 1749 834922
Email: john.grange@anonymised.com
BlueFinger Limited
Underwood Business Park, Wookey Hole Road, Wells, Somerset, BA5 1AF, UK
Tel: +44 (0) 1749 834900
Fax: +44 (0) 1749 834902
Mobile: +44 (0) 7876 038058
web: www.bluefinger.com <http://www.bluefinger.com>
Company Reg No: 4209395 Registered Office: 2 Temple Back East, Temple Quay, BRISTOL. BS1 6EG.
*** This E-mail contains confidential information for the addressee only. If you are not the intended recipient, please notify us immediately. You should not use, disclose, distribute or copy this communication if received in error. No binding contract will result from this e-mail until such time as a written document is signed on behalf of the company. BlueFinger Limited cannot accept responsibility for the completeness or accuracy of this message as it has been transmitted over public networks.***
-----Original Message-----
From: cholmes@anonymised.com [mailto:cholmes@anonymised.com]
Sent: Wednesday, April 14, 2004 3:26 PM
To: Grange, John
Cc: geoserver-devel@lists.sourceforge.net; jgarnett@anonymised.com
Subject: RE: [Geoserver-devel] Oracle Support
Ah, I didn’t know that I had people who were testing out oracle who
would be willing to give feedback. The big problem is that
none of the
current main geoserver developers have an oracle spatial database to
play with. I tried to set one up several times a long while ago on
linux but it just kept falling over on the install, and just
don’t have
the time to set it all up right now. And the contributor of
the oracle
stuff, who the list usually relies on to carry the oracle load, is
really busy on his main work. So if you have time the next few days
I’ll do what I can to help you out, make it one of my top priorities,
as I didn’t even know that oracle was completely not working. If you
know of an oracle install that I could connect to from outside that
would be the most helpful, as I can try it out myself. Barring that
you can send me detailed error messages and logs, and I can try to
diagnose the problem.
I did update the advanced.xml document in cvs to reflect the latest
changes that I know about, but there are things I’m not sure
of since I
can’t test it myself.
The one thing I do know is that the gt2-oracle-spatial jar is
no longer
being included in the install, because it leads to the web application
some how malfunctioning. I didn’t quite understand this, Jody, could
you explain more?
The thing to do now is to download the latest geotools
release which is
available at
http://prdownloads.sourceforge.net/geotools/geotools-bin-2.0-B
3.zip?download
, and then copy the gt2-oracle-spatial jar into WEB-INF/lib directory
of the expanded war, along with the two other oracle jars
needed (these
were required before, I believe). If working from the source and
building the war yourself then you need to comment out the line of the
war build that says ‘’, so
that it gets copied over to the war.
I believe the real fix will be when the oracle datastore factory can
detect if the extra jars are present (which actually shouldn’t be too
hard to do, I can try to get it working). Though actually putting the
gt2-oracle-spatial jar in without the other too seems a bit much,
perhaps we should just make the oracle spatial jar downloadable from
sourceforge, with instructions there?
Ok, let’s move this discussion over to
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-149 , so we’re
not flooding the list. I’ll post these comments there too, but yeah,
I’d love to get to the bottom of this issue, and I apologize for not
giving it more attention, but it’s quite hard when I don’t have an
oracle install.
Chris
Quoting “Grange, John” <john.grange@anonymised.com.221…>:
Mark,
I’ve completely given up trying to use the web configuration for
oracle - I
get the same message as you. If you try setting things up manually,
though,
it still doesn’t work, but you do get new and interesting error
messages to
confuse you :slight_smile:
Regards
John Grange
BlueFinger Limited
UK
web: www.bluefinger.com <http://www.bluefinger.com/>
East, Temple
Quay,
BRISTOL. BS1 6EG.
only. If
immediately. You
should
in
time as a
Limited
accuracy of this
Sent: Tuesday, April 13, 2004 2:28 PM
To: geoserver-devel@lists.sourceforge.net
I am concerned about this as well. I am a new user, just installed
for the first time. I love the concept, but the first thing I tried
to do
was create a connection to an Oracle Spatial database I
have here and
I
haven’t been able to get the parameters to be processed. I was
thinking that
I was doing something wrong, but John’s email has me thinking that
the
Oracle support isn’t there yet? Can someone clarify this
for me? Thx.
Mark Adams
Business & Systems Analyst
Cuesta Systems Inc.
5230 South Service Road
Burlington, ON L7L 5K2
Phone: 905-333-4544 x14
Fax: 905-333-0455
Email: markadams@anonymised.com
[mailto:geoserver-devel-admin@lists.sourceforge.net] On Behalf Of
Grange,
John
Sent: Tuesday, April 13, 2004 5:31 AM
To: ‘geoserver-devel@lists.sourceforge.net’
Subject: [Geoserver-devel] Oracle Support
Please could somebody tell me what the current status is of
Oracle in
geoserver.
Geoserver appears very promising for the applications I develop, but
if I
can’t get it to work with oracle, it’s useless for me.
And yes, I have followed the available instructions to get it
working. And
where did the gt2-oracle-spatial.jar go?
John Grange
BlueFinger Limited
UK
web: www.bluefinger.com < http://www.bluefinger.com
<http://www.bluefinger.com> >
East, Temple
Quay,
BRISTOL. BS1 6EG.
only. If
immediately. You
should
in
time as a
Limited
accuracy of this
This mail sent through IMP: https://webmail.limegroup.com/
Did manage to get oracle **sort** of working yesterday - I think my
the CVS
head. I'll try a few more things tonight and let you know how I get
on.
Cool. Take good notes and we'll turn them into the new docs. Stuff
like this has me itching to take geoserver over to confluence and wiki
as well, as then it wouldn't necessary for all little updates to go
through me. Perhaps we can borrow a bit of the geotools wiki for now
where you can put the info up. Would be nice to have little how to's
for each datastore actually, those would be in the scope of geotools,
and then maybe we could squeeze a bit about geoserver specific stuff in
too.
I don't have a public facing oracle, but I'll try to search oracle's
technet
there
Cool. Yeah, I no longer have time to set it up, and the computer I'd
put it on is in New York. But if you find them it'd be a nice resource
to have.
Chris
I'll now take this discussion to the jira issue as requested.
John Grange
BlueFinger Limited
UK
Quay,
BRISTOL. BS1 6EG.
only. If
should
in
time as a
Limited
> To: Grange, John
> Ah, I didn't know that I had people who were testing out oracle who
> none of the
to
> don't have
> the oracle
days
> I'll do what I can to help you out, make it one of my top
priorities,
> as I didn't even know that oracle was completely not working. If
you
that
> changes that I know about, but there are things I'm not sure
> of since I
> can't test it myself.
> no longer
application
> some how malfunctioning. I didn't quite understand this, Jody,
could
> you explain more?
> release which is
> available at
3.zip?download
directory
> needed (these
the
> war build that says '<exclude name="**/gt2-oracle-spatial.jar"/>',
so
can
> detect if the extra jars are present (which actually shouldn't be
too
the
from
> Ok, let's move this discussion over to
we're
> not flooding the list. I'll post these comments there too, but
yeah,
> I'd love to get to the bottom of this issue, and I apologize for
not
> giving it more attention, but it's quite hard when I don't have an
> oracle install.
> Chris
> Quoting "Grange, John" <john.grange@anonymised.com>:
> > Mark,
> > I've completely given up trying to use the web configuration for
> > oracle - I
manually,
> > though,
> > it still doesn't work, but you do get new and interesting error
> > messages to
> > Regards
> > John Grange
> > BlueFinger Limited
1AF,
> > UK
> > web: www.bluefinger.com <http://www.bluefinger.com/&gt;
> East, Temple
> > Quay,
> > BRISTOL. BS1 6EG.
addressee
> > only. If
> immediately. You
> > should
received
> > in
such
> > time as a
> > Limited
> accuracy of this
> > From: Mark Adams [mailto:markadams@anonymised.com]
installed
> > GeoServer
tried
> > to do
> have here and
> > I
> > haven't been able to get the parameters to be processed. I was
> > thinking that
> > I was doing something wrong, but John's email has me thinking
that
> > the
> > Oracle support isn't there yet? Can someone clarify this
> for me? Thx.
> > Mark Adams
> > Cuesta Systems Inc.
> > Fax: 905-333-0455
> > From: geoserver-devel-admin@lists.sourceforge.net
> > Grange,
> > John
> > To: 'geoserver-devel@lists.sourceforge.net'
> Oracle in
> > geoserver.
but
> > if I
> > can't get it to work with oracle, it's useless for me.
> > working. And
> > John Grange
> > BlueFinger Limited
1AF,
> > UK
> East, Temple
> > Quay,
> > BRISTOL. BS1 6EG.
addressee
> > only. If
> immediately. You
> > should
received
> > in
such
> > time as a
> > Limited
> accuracy of this
