Hmmmm… not really, the worst thing that should happen is that the resulting SVG document were pretty big, but it should give you a complete and well formatted svg document anyway.
So, it is possible that this behavoir be caused by a bug or something extrange.
Please set the logging level to FINER and send the logs.
Best regards,
gabriel
-----Mensaje original-----
De: Olivier BONNEFON [mailto:bonnefon.safer48@anonymised.com]
Enviado el: jueves, 13 de mayo de 2004 16:27
Para: geoserver-devel@anonymised.com
Asunto: [Geoserver-devel] polygons number limited with svgHello, I’m trying to explore postgis polygons databases with Geoserver 1.2. With small databases there’s no problem, but with a great number of polygons svg files seems to be truncated or incompletely transmited. Is there a maximum limit for the polygons number per database or is there something special to do ? Could you help me please ?
Thank you.Olivier BONNEFON
SAFER LozèreTél. (0)4.66.49.00.90
Fax. (0)4.66.65.35.28
Mél. bonnefon.safer48@anonymised.com
