RE: [Geoserver-devel] Re: [deegree-devel] Geoserver issues
Andreas,
If you are right, I would mean that Geoserver only supports kvp requests...
Is it true?
Thanks for your help,
Marc-André
-----Original Message-----
Sent: Friday, September 17, 2004 4:04 AM
To: deegree-devel@lists.sourceforge.net
Cc: geoserver-devel@anonymised.com
Subject: [Geoserver-devel] Re: [deegree-devel] Geoserver issues
Morin, Marc-André wrote:
>Hi,
>I'm using Geoserver1.1.1/Postgis0.8 to distribute some data.
I would like
>to be able to access these data from the deegree
Viewer/Converter version
>1.3.7.
>However, when I try to run a GetFeature request, I obtain
the following
>error from Geoserver:
><?xml version="1.0" ?>
><ServiceExceptionReport
> version="1.2.0"
> xmlns="http://www.opengis.net/ogc&quot;
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
> xsi:schemaLocation="http://www.opengis.net/ogc
>http://localhost:8080/GridRetriever/data/capabilities/wfs/1.0
.0/OGC-exceptio
>n.xsd">
> <ServiceException>
> No wfs kvp request recognized. The REQUEST parameter
must be one of
>GetFeature, GetFeatureWIthLock, DescribeFeatureType, LockFeature, or
>Transaction. </ServiceException>
></ServiceExceptionReport>
>I have been able to perform a GetCapabilities and a
DescribeFeatureType
>request successfully...
>Also, I don't get any error if I run a GetFeature request
from my IE web
>browser...
>What is wrong?
>Any help would be appreciated!
>regards,
>Marc-André
Hi Marc-André,
it looks like that you tried to send a GetFeature request as KVP
encoding. If this is true, that's the error. The deegree
viewer doesn't
support sending GetFeature through HTTP-GET using KVPs.
best regards
ANDREAS
Dr. Andreas Poth
l a t / l o n GmbH
Meckenheimer Allee 176 53115 Bonn, Germany
phone ++49 +228 732838 fax ++49 +228 732153
http://www.lat-lon.de http://www.deegree.org
This SF.Net email is sponsored by: YOU BE THE JUDGE. Be one of 170
Project Admins to receive an Apple iPod Mini FREE for your
judgement on
who ports your project to Linux PPC the best. Sponsored by IBM.
Deadline: Sept. 24. Go here: http://sf.net/ppc_contest.php
Geoserver-devel mailing list
No, GeoServer definitely supports xml post requests. The one thing may
be that it is sent to the wrong location. GeoServer 1.1 put its post
locations at different urls. This is within the scope of the spec, but
many naive clients assume that all go to the same location, such as
http://…/geoserver/wfs, instead of sending it to
http://…/geoserver/wfs/GetFeatures (as is advertised in the caps
document). I imagine that's probably what the client is doing, as it's
sort of a bitch to really parse the capabilities document fully, when
all the examples in the wfs spec use the same base location.
But we did improve this in GeoServer 1.2, to work with the more naive
clients out there, so if you upgrade then that may fix your problems.
best regards,
Chris
Quoting "\"Morin, Marc-André\"" <Marc-Andre.Morin@anonymised.com>:
Andreas,
requests...
Is it true?
Marc-André
> From: Andreas Poth [mailto:poth@anonymised.com]
> >Hi,
> I would like
> >1.3.7.
> the following
> > version="1.2.0"
> .0/OGC-exceptio
> >n.xsd">
> > <ServiceException>
> must be one of
or
> DescribeFeatureType
> from my IE web
> >browser...
> >What is wrong?
> >regards,
> >Marc-André
> Hi Marc-André,
> viewer doesn't
> best regards
> ANDREAS
> Dr. Andreas Poth
> l a t / l o n GmbH
> judgement on
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Project Admins to receive an Apple iPod Mini FREE for your judgement
on
This mail sent through IMP: https://webmail.limegroup.com/
