RE: [Geoserver-devel] Re: Question about ArcSDE connection
Hello,
I was looking for the same thing, but I cannot find sde9.0 jar file anywhere. So I ended up installing the latest SDE SDK to get the jar
File.
Eddy
-----Original Message-----
From: Gabriel Roldán [mailto:groldan@anonymised.com]
Sent: Thursday, November 04, 2004 4:45 AM
To: Kuo, Eddy Y
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] Re: Question about ArcSDE connection
good news,
thanks for the info.
Do you know if the sde9.0 jar is publicly available somewhere?
best regards,
gabriel
On Thu, 2004-11-04 at 00:03, Kuo, Eddy Y wrote:
I will answer my own question. With the geoserver binary
distribution, the arcsde connection
Came with sde 8.3 jar file, and it does not work with SDE 9.0 server.
All I have to do
Is to replace the sde 8.3 jar file with sde 9.0 jar file, and
everything works.
Eddy
Gabriel Roldán (gabriel.roldan@anonymised.com)
Director
Axios Engineering
te: (+34) 94 441 63 84
fax: (+34) 94 441 64 90
Hmmm... I wonder what thier distribution policy with the sdk and the
resulting jar is - if it'd be kosher for us to distribute that jar. And
also if it's backwards compatible with 8.3.
Also, if you (or anyoneone reading this) want to do a nice contribution to
the geoserver community, you could figure out how to do views with arcsde,
we've heard reports of them failing, but I don't know arcsde well enough
to create the views myself. I actually do have limited access to an sde
instance, so if anyone could tell me how one might create a view (in very
basic terms, I don't even know how to create a table in arcsde), then I
can take a shot at debugging geotools to work with it.
best regards, and thanks for the tip about getting things working with sde
9, I'll include a note in the next release.
Chris
On Thu, 4 Nov 2004, Kuo, Eddy Y wrote:
Hello,
File.
Eddy
To: Kuo, Eddy Y
good news,
