Hi Gabriel,
Yes the data is a valuable part of WFS along with all the filter
query capability. The mixed namespace on attribute retrieval is a good idea.
Any thoughts about an approach to adding event listener attributes on svg
elements as part of the outputstream?
Thanks
Randy
-----Original Message-----
From: Gabriel Roldán [mailto:groldan@anonymised.com]
Sent: Tuesday, October 18, 2005 10:41 AM
To: Randy George
Subject: Re: [Geoserver-devel] Re: SVG Rendering
Hi Randy,
actually I would like SVG as an output format for WFS too, though I would
approach differently the WMS encoding from the WFS encoding.
Both should be streamed, yes, but what I mean is that for WMS we need
styling,
which is a somewhat complicated thing, so the best we can do (afaik) is to
reuse the Batik stuff to the greater extent possible, maintaining, at least
partially, a streamed approach, as described in the previous mail.
WFS is another thing. The valuable part of an WFS SVG output is the data,
not
the styling, and the best approach would be to mix namespaces, for example:
<svg ....>
<svg:path id="road.1" ....>
<gml:name>featureName</gml:name>
<topp:length>70</topp:lenght>
</svg:path>
and this can indeed be done fully streamed. We already have a good framework
to do that when encoding gml and also have code to encode JTS geometries to
SVG. So yes, I'm really for it, and just hope to find the time to get a bit
more involved in this kind of issues in the short term. For the moment, all
I
can compromise to is to try my idea of getting batik styling working in a
semi-streamed fashion, and commit it if succesful.
thanks for your support,
Gabriel.
On Tuesday 18 October 2005 17:21, Randy George wrote:
Hi Justin,Gabriel,
Thanks for digging into this. I am looking forward to having SVG as
a format option. If the outputstream approach works can it also be a
format
option on WFS as well as WMS?
Thanks
Randy-----Original Message-----
[mailto:geoserver-devel-admin@lists.sourceforge.net] On Behalf Of Gabriel
Roldán
Sent: Tuesday, October 18, 2005 10:11 AM
To: Justin Deoliveira
Cc: Geoserver-devel
Subject: [Geoserver-devel] Re: SVG RenderingHi Justin,
looks good.
I don't remember what the cause was for the memory leak problem involving
clearLayerList(), though I'm aware the problem existed and that was the
solution.By the way, I was investigating a way of streaming Batik, and looks like
we
could be able to get an in-the-middle solution. I mean, writing a subclass
of
Batik's AbstractGraphics2D that instead of making a DOM grow up
indefinitelly
just writes up xml to an outputstream in an element by element basis.
So my plan is first getting that working, then minimizing the verbosity of
generated svg by replacing by-element styling with CSS and class=
attributes.This would give us a much more memory friendly svg producer with full
styling,
though I don't think I'll have time to dig into it until weekend.cheers,
Gabriel.
On Tuesday 18 October 2005 07:11, Justin Deoliveira wrote:
> Hi Gabriel,
> I have been looking at geoserver's svg rendering as per
> http://jira.codehaus.org/browse/GEOS-400
> I tracked the problem down to GetMapResponse. There are two methods of
> interest:
> execute(Request), and writeTo(Request).
> The GetMapResponse releases resources of the MapContext
> (MapContext#clearLayerList()) at the end of the execute() method, which
> means that when the SVGMapProducer doesn't have any layers to render in
> the writeTo() method.
> I changed it so that the resources arent released until the end of the
> writeTo() method, which is the end of the requests life cycle.
> The change is pretty simple but i thought I would run it by you first
> since the devil is often in the details.
> On another note, I created another GetMapProducer that produces svg
> using batik instead of the render that you wrote. The bad news is it is
> slow (no suprise), however it does all the styling.
> So we have a couple of options:
> 1. Only use one of working renders, or
> 2. Use both, and make it part of the WMS configuration which one to use.
> Any thoughts?-------------------------------------------------------
This SF.Net email is sponsored by:
Power Architecture Resource Center: Free content, downloads, discussions,
and more. http://solutions.newsforge.com/ibmarch.tmpl
Geoserver-devel mailing list
