RE: [Geoserver-devel] WFS-request on a database view ?
Im not sure why this doesn't work already. You should be able to specify the name of the view in place of the table and Geoserver will use that view. We shouldn't need to do anything special in Geoserver or Geotools to support this.
Sean
-----Original Message-----
From: cholmes@anonymised.com [mailto:cholmes@anonymised.com]
Sent: Thursday, 15 April 2004 2:53 PM
To: Katterfeld, Christiane
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] WFS-request on a database view ?
> is it possible to put a WFS-request on a database-view
(instead of a =
> table) ?
> We are using geoserver WFS with postgis. The view is the
result of the
> = following SQL-Query:=20
> CREATE OR REPLACE VIEW public.loesch AS SELECT "ID", "FB",
"Name", =
> "Beschreibung", "Adresse", "Geb-ID", "Datum", "Beginn",
"Ende", layer,
> = color, name, strasse, z, zd_farbe, bemerkung, id, the_geom=20
> FROM (test_veranstaltungen LEFT JOIN unigebaeude ON =
> ((test_veranstaltungen."Geb-ID" =3D unigebaeude.id )));=20
> (One table contains geometry and the other one contains no geometry.
> Both are linked by a key. )
No, not yet, I'm sorry. There has been talk of doing such things, but
the most you can do right now is limit the columns in a table, so that
not all attributes of a row are shown. There has been talk of doing
this, making a 'pass-thru' sql query that you could specify, but it
needs to be done in geotools, and no one has really had the motivation
to put the time in to code it up and make api changes. But it is on
our radar, and will be done at some point, just not yet. Sorry.
Chris
This mail sent through IMP: https://webmail.limegroup.com/
This SF.Net email is sponsored by: IBM Linux Tutorials Free Linux
tutorial presented by Daniel Robbins, President and CEO of GenToo
technologies. Learn everything from fundamentals to system
administration.http://ads.osdn.com/?ad_id=1470&alloc_id=3638&op=click
Geoserver-devel mailing list
Oh wait, you might be right. Sorry, I was thinking of defining the view
just with the sql statement directly, which mapserver allows you to do,
without actually calling it a view in the database. You're right, this
might work, and if it doesn't it probably should. I'll try to test it
out this afternoon.
Chris
Sean
> (instead of a =
> > table) ?
> result of the
> "Name", =
> "Ende", layer,
geometry.
but
that
doing
motivation
on
> Chris
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Free Linux tutorial presented by Daniel Robbins, President and CEO of
GenToo technologies. Learn everything from fundamentals to system
Nope, this doesn't work right now. But we should try to get it working,
as it may be easier than I thought. The first problem is that our
JDBCDataStore limits the search of available tables to types { "TABLE"
So at the least that should be { "TABLE", "VIEW"}. I'm having major
sourceforge troubles right now, so I can't get the update in any time
soon.
We might run into some problems with postgis, with the geometry_columns
table, as we rely on it pretty heavily, and I kind of doubt it's smart
enough to figure out what column a view really is of. Though I could
be wrong. That would just mean that users who really wanted views
would have to add the table by hand.
Chris
view
do,
this
it
out this afternoon.
Chris
will
Geoserver
> Sean
> > (instead of a =
> > > table) ?
> > result of the
> > "Name", =
> > "Ende", layer,
> geometry.
things,
> but
> that
> doing
it
> motivation
> on
> > Chris
> > _______________________________________________
of
Ok, further testing of this reveals that things fail for postgis on the
issue of the fid. Perhaps Andrea's fid work will help us out here, but
basically the view I created does not automatically pick up a primary
key, thought maybe there's a way to define a primary key in a view?
I'm not a sql expert... Postgis then defaults to oid, which a row in a
view does not have either, so it fails. I do still suspect that the
geometry will also need a lookup in the geometry_columns table. So
this will be possible with a bit of work, but not right now.
Chris
view
do,
this
it
out this afternoon.
Chris
will
Geoserver
> Sean
> > (instead of a =
> > > table) ?
> > result of the
> > "Name", =
> > "Ende", layer,
> geometry.
things,
> but
> that
> doing
it
> motivation
> on
> > Chris
of
