RE: [Geoserver-devel] WMS GetCapabilities - Timed Out
-----Mensaje original-----
De: Swapan Mazumdar [mailto:swapan@anonymised.com]
Enviado el: lunes, 03 de mayo de 2004 10:18
Para: geoserver-devel@lists.sourceforge.net
Asunto: RE: [Geoserver-devel] WMS GetCapabilities - Timed Out
Gabriel,
You didn't misunderstood my question. With the help of your direction I
have been able to view SVG (getMapSvg.url)
through my IE. I think providing reference to local copy of the WMS DTD
will be a great idea. I am still
getting operation timeout.
Does it mean that I would have difficulty accessing local WMS?
May be it just means you'll have problems to load the GetCapabilities
document with a validating client, in the case it wouldn't be able to
validate against the remote DTD.
Actually you'll have no problem with GetMap queries, since the result is a
plain image, not XML. (well, it is for SVG ones, but that's another
question)
I have been wondering how you people test the functionality like zoom
in/out, pan, add feature, query etc.
I think we don't yet :frowning:
What Mapping tool you use in particular. I am trying to setup GeoClientX
tool (MapBuilder) but stuck with
some issues. Could you pl. look into my post with subject
-geoclientx(MapBuilder) and Geoserver, Dated - Fri 2004/04/30
I just use a propietary one from my company. (but I'm working in a thin
html/javascript WMS client now. anyway, do not expect to see it before two
weeks or so:(
Sorry about the bad news, I really hope to provide stronger WMS support
sooner.
best regards,
Gabriel
I would like to integrate a mapping tool like GeoClientX with GeoServer.
What Open Source Client Tool you would suggest.
I would appreciate your suggestions.
Swapan Mazumdar
-----Original Message-----
From: Gabriel Roldán [mailto:gabriel.roldan@anonymised.com]
Sent: 30 April 2004 04:18 PM
To: Swapan Mazumdar
Cc: geoserver-devel@anonymised.com
Subject: Re: [Geoserver-devel] WMS GetCapabilities - Timed Out
Swapan Mazumdar wrote:
From within the GeoServer App Welcome page, the GetCapabilities link
of wms returns a page with timeout error like below:
The XML page cannot be displayed
Cannot view XML input using style sheet. Please correct the error and
then click the Refresh button, or try again later.
The operation was timed out. Error processing resource
'http://www.digitalearth.gov/wmt/xml/capabilities_1_1_1.dtd’.
digitalearth.gov is the mandatory repository for the WMS dtd's. It seems
that your browser (IE?) couldn't access that resource at the time when
you made the query. Anyway, I suppose we should be allowed to reference
a local copy of the WMS DTD's just as it is done with WFS schemas.
What geoserver people think?
1) Why is it referring to a resource from igitalearth.gov and timed
out? Pl. note that from the Demo section of GeoServer App, all the
dropdown request works well except the getMapSvg.url
(http://localhost:8080/geoserver/wms?request=GetMap&layers=bc_roads&bbox=489
153,5433000,529000,5460816&width=800&height=400&srs=EPSG:27354&styles=normal
&Format=image/svg+xml
<http://localhost:8080/geoserver/wms?request=GetMap&layers=bc_roads&bbox=489
&Format=image/svg+xml>).
This tries to download a file from the geoserver without processing
the script/code. 2) Why does this request fails to execute?
I ll appreciate any response in this regard.
Svg is an XML image format developed by W3C. Currently no browsers
except some versions of mozilla have native support for it, although
they will in the short term since SVG is a w3c recomendation (==
standard). So, in order to be able to load SVG images, your browser must
have a plugin instaled. The most widely used is the Adobe SVG Viewer,
wich you can download and install from Adobe's web site
(http://www.adobe.com/svg/viewer/install/main.html)
Hope this helps. If not, please tell me, perhaps I missunderstand your
problem/question.
Gabriel Roldán.
Swapan Mazumdar
This SF.Net email is sponsored by: Oracle 10g
Get certified on the hottest thing ever to hit the market... Oracle 10g.
Take an Oracle 10g class now, and we'll give you the exam FREE.
http://ads.osdn.com/?ad_id149&alloc_id66&op=click
Geoserver-devel mailing list
