Jonas,
FYI, there is a MapBuilder WPS demo that I did for the WPS IE last summer.
However be warned that it's based on the 0.2.4 version of the spec and many
of the services that I tested against are gone, so it definitely needs an
update, but with a little bit of work, it could be a client interface to
test with.
Try clicking on the "GDAS XML Stream Based Geoprocessing Service (AAFC)"
link in the sidebar at http://geoservices.cgdi.ca/mapbuilder/demo/wpsIE/
(and imagine a map showing up It will step through getCapabilities,
describeProcess, setting parameters and execute process. The intention with
this interface is that the map can be used as a source of inputs and for
displaying outputs. Combine that with some of the feature selection and
rendering stuff going on in MapBuilder and there is a good start to a WPS
client.
Mike
-----Original Message-----
[mailto:geoserver-devel-admin@lists.sourceforge.net] On
Behalf Of Jonas Johansson
Sent: March 16, 2006 1:34 PM
To: Geoserver-devel
Subject: [Geoserver-devel] Working WPSHi all,
Alright, the WPS is working. One process/calculation is
supported right
now: caclulating a buffer on a MultiLineString or some other
simple JTS Geometry. It kind of fulfils the WPS 0.4.0 spec
requirements in doing that, but exceptions are not handled
correctly yet, and there are probably lots of bugs, and I
have only tried it locally.The WPS handles the operations
* GetCapabilities
* DescribeProcess
* ExecuteThe GetCapabilities operation gives you the usual info plus a
brief description of each process that the WPS serves
(currently just one).The DescribeProcess operation is called supplying one or many
identifiers for processes that was given in the
GetCapabilities response. The DescribeProcess response is a
list of detailed descriptions for each process specified,
giving detailed information on possibly required inputs and
generated output:
<ProcessDescriptions>
<ProcessDescription>
<DataInputs>
<ProcessOutputs>
</ProcessDescription>
</ProcessDescriptions>The Execute operation is supplied with the identifier of the
process that should be executed, and the possibly required
input and possibly also definitions of how outputs should be
generated.I have been following the GeoServer style of handling
services, so there has been lots of copy&pasting+editing. The
GUI is not updated with WPS.The implementation is an ugly one right now, adding the
ProcessDescription of the Process in static code. Future
plans are to use GTXML for reading in the ProcessDescription
from an XML. The Process interface is probably not the best
one either. But hey, it works =)But before fine-tuning the WPS I have to get a client
working, that uses the WPS in combination with WMS, to
calculate a buffer around road segments. The plan is to use
uDig as a base for that.Jonas
This SF.Net email is sponsored by xPML, a groundbreaking
scripting language that extends applications into web and
mobile media. Attend the live webcast and join the prime
developer group breaking into this new coding territory!
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=110944&bid=241720&
dat=121642
Geoserver-devel mailing list
