It should probably be mentioned that other people may come across the
same kind of thing if they are running geoserver and coldfusion servers
under jrun on the same machine. It only happened to me because we had
another developer using geotools with coldfusion for a project that I'm
not involved in, and hence had no idea she was using it.
Coldfusion, for some reason, modifies Jrun's default JVM configuration.
All Jrun's servers (even though they are running as separate processes)
use the same configuration by default. Coldfusion adds its own library
path as a JNI library path to this configuration.
That means any libraries that coldfusion uses, geoserver will use by
default too, even though they are running under separate processes.
To rectify, either coldfusion or geoserver should be set to use a custom
JVM configuration.
The details of how to make a Jrun server start using a custom
configuration can be found at http://www.adobe.com/go/tn_18206/.
All I did was copied the default JVM configuration and removed any
references to coldfusion, then applied it as a custom configuration to
geoserver.
I can put this in the wiki if somebody would let me know where to put
it.
Miles Jordan
Applications Developer
The Australian Antarctic Data Centre
-----Original Message-----
[mailto:geoserver-users-admin@lists.sourceforge.net] On
Behalf Of Miles Jordan
Sent: Tuesday, 16 May 2006 10:54 AM
To: Justin Deoliveira
Cc: Brent Owens; geoserver users
Subject: RE: [Geoserver-users] GeoServer 1.3.1-beta releaseI think you were right about the duplicate class Justin.
I found a geotools2 jar in the global lib directory of Jrun
for some reason, which is probably causing all the problems.Thanks,
Miles Jordan
The Australian Antarctic Data Centre> -----Original Message-----
> From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
> Sent: Tuesday, 9 May 2006 10:12 PM
> To: Miles Jordan
> Subject: Re: [Geoserver-users] GeoServer 1.3.1-beta release
> In my experience a NoSuchMethodError usually means one of
two things:
> 1. Duplicate entries of a class on your classpath
> 2. A java 4 vs java 5 problem.
> -Justin
> Miles Jordan wrote:
> > Hi Brent,
> > I've installed the 1.3.1 war, and removed all the example
> featuretypes,
> > styles stores and namespacews except for the giantpolygon
> style and the
> > store and namespace it uses.
> > I made a new namespace with no problems.
> > When I click on 'New' to make my new Store, I get
> > [ServletException
> in:/WEB-INF/pages/data/DataConfigDataStoresNew.jsp]
> > Getter for property dataStoreDescriptions threw exception:
> > java.lang.NoSuchMethodError:
> org.geotools.data.DataStoreFactorySpi.getDisplayName()Ljava/la
> ng/String;
> > Miles
> > Miles Jordan
> >>From: geoserver-users-admin@lists.sourceforge.net
> >>Behalf Of Brent Owens
> >>Sent: Sunday, 7 May 2006 12:48 PM
> >>To: geoserver users; Geoserver-devel; GeoTools Devel List;
> >>geotools-gt2-users@lists.sourceforge.net
> >>Subject: [Geoserver-users] GeoServer 1.3.1-beta release
> >>The GeoServer team is proud to announce the beta release of
> >>GeoServer 1.3.1. The main change in this release is the
> >>addition of GeoTools 2.2.x that
> >>includes many new features, bug fixes, and an improved renderer.
> >>You can download the release here:
> >>http://docs.codehaus.org/display/GEOS/Latest
> >>Remember that it is a beta version and not recommended for a
> >>production
> >>environment. But please try it out and give us feedback. An
> official
> >>1.3.1 release should be out shortly containing all of the
> 1.3.1 Jira
> >>tasks, including PDF output support.
> >>Brent Owens
> >>(The Open Planning Project)
> >>Using Tomcat but need to do more? Need to support web
> >>services, security? Get stuff done quickly with
> >>pre-integrated technology to make your job easier Download
> >>IBM WebSphere Application Server v.1.0.1 based on Apache
> >>Geronimo
> >>http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&
> > dat=121642
> > _______________________________________________
> > Geoserver-users mailing list Geoserver-users@lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geoserver-users
> ______________________________________________________________
> _____________
> > Australian Antarctic Division - Commonwealth of Australia
> > IMPORTANT: This transmission is intended for the addressee
> only. If you are not the
> > intended recipient, you are notified that use or
> dissemination of this communication is
> > strictly prohibited by Commonwealth law. If you have
> received this transmission in error,
> > please notify the sender immediately by e-mail or by
> telephoning +61 3 6232 3209 and
> > DELETE the message.
> > Visit our web site at http://www.aad.gov.au/
> _____________
> services, security?
> > Get stuff done quickly with pre-integrated technology to
> > Download IBM WebSphere Application Server v.1.0.1 based on
> Apache Geronimo
> > http://sel.as-us.falkag.net/sel?cmd=lnk&kid0709&bid&3057&dat1642
> Justin Deoliveira
_____________Australian Antarctic Division - Commonwealth of Australia
only. If you are not the intended recipient, you are notified
that use or dissemination of this communication is strictly
prohibited by Commonwealth law. If you have received this
transmission in error, please notify the sender immediately
by e-mail or by telephoning +61 3 6232 3209 and DELETE the message.
_____________-------------------------------------------------------
Geronimo
http://sel.as-us.falkag.net/sel?cmd=k&kid0709&bid&3057&dat1642
___________________________________________________________________________
IMPORTANT: This transmission is intended for the addressee only. If you are not the
intended recipient, you are notified that use or dissemination of this communication is
strictly prohibited by Commonwealth law. If you have received this transmission in error,
please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and
DELETE the message.
