RE: [Geoserver-users] GeoServer + PostGis + Pgdijkstra Routing Module
Alvaro,
The Kamap guys have been investigating doing something similar with the pgdjikstra module. I'd highly advise reading through some of the topics in http://lists.maptools.org/pipermail/ka-map-users/2006-January/thread.html
to gain an understanding of some of the problems faced when doing dynamic overlays.
I also did a post on my blog at http://chris.narx.net/2006/02/05/adding-routing-overlays-to-kamap/ which may give you some further insight.
Chris
-----Original Message-----
From: geoserver-users-admin@lists.sourceforge.net [mailto:geoserver-users-admin@lists.sourceforge.net] On Behalf Of Álvaro Gutiérrez
Sent: Tuesday, 28 February 2006 7:50 PM
Subject: [Geoserver-users] GeoServer + PostGis + Pgdijkstra Routing Module
I've integrated Pgdijkstra Routing Module with PostGis. I've done some
tests, with PgAdmin. I've loaded some streets, and tried "shortest_path"
function between two sites and worked very well, as I obtained a list of
four streets with their "geom" data as MultiLineString.
My problem, maybe, is related with the fact that i don't know very well
how GeoServer works with, for example, MapBuilder as client. What i want
to do is having a web page with a map, streets, inside it and a litle
form where you can ask for the shortest route between two streets. And
you have to recive as response the map with a MultiLineString layer,
drawing the result obtained from PostGis, over the Map, and perhaps the
list of the streets and the length for them, this is obtained from
"shortest_path" function.
Thanks everyone.
PD: Sorry for my english.
This SF.Net email is sponsored by xPML, a groundbreaking scripting language
that extends applications into web and mobile media. Attend the live webcast
and join the prime developer group breaking into this new coding territory!
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=110944&bid=241720&dat=121642
Geoserver-users mailing list
This e-mail and any files transmitted with it are intended only for the use of the addressee(s). It may contain information that is confidential and privileged. If you are not an intended recipient, any use, interference with, disclosure, distribution or copying of this material is unauthorised and prohibited. If you receive this in error, please notify the author by Return email to the sender. Information in this message not relating to the official business of DLI shall be understood as neither given nor endorsed by it. While every care is taken, it is recommended that you scan any attachments for viruses. DLI liability is limited to re-supplying affected attachments.
PLEASE NOTE: All dola.wa.gov.au and vgo.wa.gov.au email addresses will soon be decommissioned. These have been replaced by dli.wa.gov.au addresses. Please ensure that your records are updated to reflect this change. Further information can be obtained by contacting our service desk on 92737533 or emailing Servicedesk@anonymised.com
Also note that users have had some success integrating GeoServer with Ka-map using squid to do the caching. So you could use ka-map as the front end and GeoServer as the backend.
best regards,
Chris
Chris Tweedie wrote:
Alvaro,
Chris
I've integrated Pgdijkstra Routing Module with PostGis. I've done some tests, with PgAdmin. I've loaded some streets, and tried "shortest_path" function between two sites and worked very well, as I obtained a list of four streets with their "geom" data as MultiLineString.
My problem, maybe, is related with the fact that i don't know very well how GeoServer works with, for example, MapBuilder as client. What i want to do is having a web page with a map, streets, inside it and a litle form where you can ask for the shortest route between two streets. And you have to recive as response the map with a MultiLineString layer, drawing the result obtained from PostGis, over the Map, and perhaps the list of the streets and the length for them, this is obtained from "shortest_path" function.
Thanks everyone.
http://sel.as-us.falkag.net/sel?cmd=lnk&kid0944&bid$1720&dat1642
Chris Holmes
The Open Planning Project
thoughts at: http://cholmes.wordpress.com
