Hey guys,
Thanks for the patch Chris, there are still some niggling issues which I will try to look at soon.
I understand where you guys are coming from re: sponsorship of the KML stuff so I’m a bit hesitant at logging too many bugs …
ArcSDE datastores keep throwing “Error building SeFilter” exceptions when requesting KML no matter how simple the SLD is.
The patch didn’t fix all issues (See attached). I haven’t looked at the KML code but its pushing out duplicate geometry for each feature (But hey, the labels work!) J
This was a quick 2 minute test, so apologies on the lack of detail. Has Jorn taken over the KML stuff or is it still a free for all as far as patches are concerned for the KML writer?
Chris Tweedie
-----Original Message-----
From: geoserver-users-admin@lists.sourceforge.net [mailto:geoserver-users-admin@lists.sourceforge.net] On Behalf Of Chris Holmes
Sent: Thursday, 16 March 2006 12:26 AM
To: Doug Fils
Cc: Geoserver-users@lists.sourceforge.net
Subject: Re: [Geoserver-users] KML output into GE via Geoserver
Doug Fils wrote:
All,
Been mostly a lurker on the site but we (http://www.chronos.org)
have installed and set up Geoserver as our WMS/WFS solution.
With the help of Chris Tweedie (thanks Chris) I got the URL to our
geoserver working with returning GE output.
ref:
When I run it I get the results… but now I have some questions.
- All the points are unlabeled, is there a way for me to pull some
data from a table in our postgis db and attach to a label name for
these points? Is this what entry:
http://jira.codehaus.org/browse/GEOS-537 regarding place names is about?
I think so. I just built geoserver with the patched file, could you
go to the issue again and download the attached geoserver.jar? Let me
know if it works…
- How do I associate data from the database into a WFS or KML output?
In the attached screen shot from that feature setup in geoserver I see
all the genus and species data with a point. (This is ocean drilling
data). I would love to see that in the white pop box in GE. Is
there something I am missing, is that related to the schema base
entry? I assume there is a link between this question and the place
name issue in item (1)?
Yes, 1) must be working properly for this to display correctly. To get
in to WFS you don’t need to do anything, all attributes are returned by
default. To get it in KML (which is generated by the WMS) you need to
make the appropriate ‘label’ in SLD. If you get the latest udig (1.1M6)
from http://udig.refractions.net you can use it to customize your SLD
with a nice gui, and then export it and upload it to GeoServer. The
lable should then be rendered in WMS, and in KML if that patch works.
Note I could only get the label working with one field at a time, but I
think it’s supposed to support more.
All the data now is Ocean based, but soon we will have GSSP markers
and asteroid impact data on-line as well, so it would be great to be
able to get this data into GE for example.
Cool. The GE support is still young, and there are some concrete things
that need to be fixed. We’ve estimated about 8 days work to get the KML
stuff up to snuff, and streaming with KMZ, which we’re not planning to
do immediately unless we can scare up a bit of funding. But reporting
bugs like this helps us know what needs to be done.
best regards,
Chris
thanks everyone!
doug
Chris Holmes
The Open Planning Project
thoughts at: http://cholmes.wordpress.com
This e-mail and any files transmitted with it are intended only for the use of the addressee(s). It may contain information that is confidential and privileged. If you are not an intended recipient, any use, interference with, disclosure, distribution or copying of this material is unauthorised and prohibited. If you receive this in error, please notify the author by Return email to the sender. Information in this message not relating to the official business of DLI shall be understood as neither given nor endorsed by it. While every care is taken, it is recommended that you scan any attachments for viruses. DLI liability is limited to re-supplying affected attachments.
PLEASE NOTE: All dola.wa.gov.au and vgo.wa.gov.au email addresses will soon be decommissioned. These have been replaced by dli.wa.gov.au addresses. Please ensure that your records are updated to reflect this change. Further information can be obtained by contacting our service desk on 92737533 or emailing Servicedesk@anonymised.com
