Randy,
Dont know what wrong with the validation in your system, but here's some
things to try:
1. remove the "<?xml version="1.0" encoding="UTF-8"?>" at the top of the
SLD file.
2. check to see that there's a
geoserver/data/capabilities/sld/StyledLayerDescriptor.xsd in your
server. Check to make sure that you can access it via http. Ie go to:
http://localhost:8080/geoserver/data/capabilities/sld/StyledLayerDescriptor.xsd
Check the other files in the directory to make sure they're accessible
too:
Here's whats in mine:
GetMap.xsd 2569 bytes Nov 22, 2005 1:11:18 PM
StyledLayerDescriptor.xsd 30194 bytes Nov 22, 2005 1:11:26 PM
expr.xsd 2521 bytes Nov 22, 2005 1:11:26 PM
feature.xsd 12813 bytes Nov 22, 2005 1:11:30 PM
filter.xsd 8477 bytes Nov 22, 2005 1:11:22 PM
geometry.xsd 14458 bytes Nov 22, 2005 1:11:20 PM
xlinks.xsd 5547 bytes Nov 22, 2005 1:11:22 PM
We know there's a few problems with the way styles work at the moment
(ie. just sticking them in a directory). In 1.3.1 we're planning on
doing a bunch of 'helpful' styles "stuff" -- I hope to get some
feedback and ideas from you when we start!
dave
This mail sent through IMP: https://webmail.limegroup.com/
