Thanks. It was easy to create the new code after your help.
Juan
-------- Original Message --------
Subject: Re: [GRASS-dev] Change the resolution in the output map
Date: Sat, 1 Dec 2007 04:36:48 +0000
To: Juan Diego Giraldo Osorio<Juan.Giraldo@upct.es>
CC: grass-dev@grass.itc.it
References: <200711301610.lAUGAbP18736@pyxis.si.upct.es>
<1228557177jdgiraldo@upct.es>Juan Diego Giraldo Osorio wrote:
> I'm working with grass62. I'm triying to create a raster map with finer
> resolution from another with coarse resolution. The problem is the next:
> - My coarse resolution map (input map) have 500 m of resolution, with
> 1000x1000 rows*cols. This information is the same as the current region .
> - I want to create a finer resolution map (output map) with 100 m of
> resolution, with 5000x5000 rows*cols.
> - I have been trying with the next code:
> /* Adjust the region to new resolution */
> region.rows = nsubpixel*nrows;
> region.cols = nsubpixel*ncols;
> region.format = 0;
> region.compressed = 1;
> G_adjust_Cell_head( ®ion , 1 , 1 );
> G_set_window(®ion);
> nsubpixel is 5 (500/100), and I'm writing a new header file with this
> new information (region.rows=5000, region.cols=5000, region.ew_res=100,
> region.ns_res=100) but when I read the new map, the next message error
> is shows:
> WARNING: error reading null row 115
> ... a lot of times.If you want to work with different resolutions, you need to
continually switch between the two. Opening and reading the input map
must be done with the source region active, while opening, reading and
closing the output map must be done with the destination region
active.See the r.resamp.interp and r.resamp.stats modules for examples.
grass-dev mailing list
grass-dev@lists.osgeo.org
Tel. 968 327 047
Departamento de Ingenier�a Térmica y de Fluidos
Universidad Politécnica de Cartagena
Espa�a
