apologize the private mail, i can see your answer on the list archive, but no reply is sent to my mail box (mybe some problems with the mailng list :-/)
Massimo Di Stefano wrote:
><i> i've old scripts that i'm using to parse the "g.proj" output
</i>> ><i> in it i have units == meters
</i>> ><i> but form recent svn 6.5 version i can see it use : metres
</i>> ><i> GRASS 6.5.svn (spearfish60):~/wxpython/data_catalog > g.proj -p
</i>
><i> -PROJ_UNITS------------------------------------------------
</i>><i> unit : metre
</i>><i> units : metres
</i>><i> meters : 1
</i>> > > ><i> is it a typo, or need i to modify my scripts to use : metre / metres ?
</i>
g.proj outputs whatever is in the PROJ_UNITS file. The textual
description of the unit can be whatever the user chooses it to be, or
in the case of "g.proj -c", whatever is obtained from the source
specified by georef=. GRASS itself only the unit/units fields for
display to the user; calculations use the numeric value in the meters
field.
What do your scripts use the "unit" or "units" field for?
I’m working on a script to send data from grass to ossimplanet,
it is :
there is a “projinfo()” function i’m using it to retrieve if the location use degrees or projected coordinates
what i need is to extract the “center of the map” and use it in the “zoom to” action.
if the location is in degrees i use :
setCLL(map)
location …
while if projected (meters) i use :
setCPRJ(map)
in the example i used the spearfish dataset.
but as you pint me … the ceck on the “units” string … is not a good idea
beacouse the “units value” is “user - dependent”
and maybe someone that did a typo error defining the location will go in an error during the script execution.
list :-/)
Note that, by default, the Mailman list management software doesn't
send a copy of a message to any user who is listed in the To, CC, etc
headers. If you don't receive the direct copy due to e.g. anti-spam
filters, then you won't receive a copy at all.
I recommend disabling this feature in your mailmain preferences:
there is a "projinfo()" function i'm using it to retrieve if the location use degrees or projected coordinates
what i need is to extract the "center of the map" and use it in the "zoom to" action.
setCLL(map)
location ..
setCPRJ(map)
I suggest looking at the PROJ_INFO output, specifically the "proj"
field. It will have the value "ll" for lat/lon.
On Tue, Feb 9, 2010 at 4:48 AM, Glynn Clements <glynn@gclements.plus.com> wrote:
list :-/)
http://lists.osgeo.org/mailman/options/grass-dev/
I've asked for this "feature" to be disabled by default, but that
hasn't happened.
I was not aware of this request (or forgot).
If there are no objections, I guess that we can change the Mailman settings.
Not sure though, if that propagates to all users or if settings are
kept (likely).
kept (likely).
> hasn't happened.
kept (likely).
Changing the default won't affect existing users. Personally, I'd be
inclined to change existing users' settings as well; they can always
change them back if they actually want it enabled. I suspect that most
people have it enabled simply because they don't know about it.
Personally, I'd be
can always
suspect that most
it.
I would be annoyed if someone changed this for me without asking.
This setting saves me time.
> Personally, I'd be
> can always
> suspect that most
> it.
While for other people, it results in them never seeing a reply to
their question.
If it was turned off, you'd know about it the first time that you got
a duplicate reply. If it's left on, people won't notice that they're
losing emails unless they happen to look at the archives or if someone
replies to the reply.
