RE: [GRASS-dev] gis.m: cannot get profile from profile tool
Hi guys,
I tried the porfiling tool with July 31 cvs, and I can't get it to work. The
y-axis gets assigned correct values for the profile I've drawn, but no lines
get drawn in the profile window. A tcltk window reports "Error: can't read
"cumdist": no such variable"
You can view the output on my ftp site:
ftp://agc.bio.ns.ca/outgoing/Patton/Grass/Bug%20Reports/
~ Eric.
-----Original Message-----
To: Michael Barton
Cc: Grass Developers List
Sent: 7/27/2006 2:33 AM
Subject: Re: [GRASS-dev] gis.m: cannot get profile from profile tool
Michael Barton wrote:
Hi Moritz,
Did you select a raster to profile?
Yes, as you can see in the screenshot, it says in the bottom left:
"Profile for srtm_be".
Third button from the left on the
profiler toolbar.
Rather like d.profile, the profiler differentiates between
a map you use as a background to the profiling line (what is shown in
the
map display) and the map that you actually use to compute profile
values.
I understand that, but I still don't get a profile. Actually, I
sometimes do not even get the straight blue line you see in the
screenshot (http://moritz.homelinux.org/grass/gism_profile.png), just an
empty graph.
The min and max of the heights on the y axis seem correct, though.
Moritz
grass-dev mailing list
grass-dev@grass.itc.it
Eric,
You failed to select a raster map to profile.
I just committed an update which does a better job of trapping this kind of
error and giving you a more meaningful error message. I also made the
profiler default to the currently selected raster map to profile and also
found a way of making the elevation ranges calculated within the currently
displayed region, using r.univar. The primary drawback of this is that it is
a bit slow to get started with enormous maps.
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Date: Mon, 31 Jul 2006 12:52:01 -0300
To: 'Moritz Lennert ' <mlennert@club.worldonline.be>, 'Michael Barton '
<michael.barton@asu.edu>
Cc: 'Grass Developers List ' <grass-dev@grass.itc.it>
Subject: RE: [GRASS-dev] gis.m: cannot get profile from profile tool
Hi guys,
~ Eric.
To: Michael Barton
Hi Moritz,
profiler toolbar.
the
values.
empty graph.
Moritz
Patton, Eric wrote:
Hi guys,
I actually got a similar error at one point, but then couldn't reproduce it...
Moritz
~ Eric.
To: Michael Barton
Hi Moritz,
Yes, as you can see in the screenshot, it says in the bottom left: "Profile for srtm_be".
profiler toolbar. Rather like d.profile, the profiler differentiates between
the
values.
I understand that, but I still don't get a profile. Actually, I sometimes do not even get the straight blue line you see in the screenshot (http://moritz.homelinux.org/grass/gism_profile.png), just an
empty graph.
Moritz
