RE: [GRASS-dev] [grass-doc I][574] v.in.ogr
Fixed in svn trunk; I'll apply it to the 63release branch soon.
~ Eric.
-----Original Message-----
From: grass-dev-bounces@lists.osgeo.org on behalf of grass-dev@lists.osgeo.org
Sent: Mon 1/7/2008 2:49 PM
To: noreply@wald.intevation.org
Subject: [GRASS-dev] [grass-doc I][574] v.in.ogr
doc I item #574, was opened at 2008-01-07 18:49
Status: Open
Priority: 3
Submitted By: Nikos Alexandris (nikosa)
Assigned to: Nobody (None)
Summary: v.in.ogr
Issue status: None
Doc section: vector
GRASS version: CVS HEAD
Doc timestamp (YYMMDD):
Initial Comment:
In v.in.ogr (in the gui), in the "output name" field [Name for output vector map:], in the descriptive text in the parenthesis it sais:
"(output: name, optional)"
Should the optional be "required"?
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=207&aid=574&group_id=21
grass-dev mailing list
~ Eric.
Status: Open
Priority: 3
Summary: v.in.ogr
Issue status: None
Doc section: vector
Initial Comment:
IIRC it is optional because you might want to just list the available layers in the input OGR source (-l flag), in which case you don't need to specify an output map.
Paul
Initial Comment:
Paul
My bad; through a weird coincidence I was already editing the description.html for v.in.ogr
when Nikos's bug report came through the list. I thought he was reporting the man page typo that I was
in the midst of correcting. I haven't changed the output parameter to 'required' either in the C code
or the docs.
~ Eric.
