On OS X with 6.4RC4 and RC5 when using Config->GIS Working
Environment->Mapset Access I get the following error:
Sun Jun 14 11:29:28 2009) Command finished (0 sec)
File
"/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpyt
hon/wxgui.py", line
366, in OnMapsets
dlg = preferences.MapsetAccess(parent=self,
id=wx.ID_ANY)
File
hon/gui_modules/prefer
ences.py", line 1732, in __init__
self.mapsetlb.LoadData(self.all_mapsets)
File
ences.py", line 1811, in LoadData
stat_info =
os.stat(mapsetPath)
OSError
[Errno 2] No such file or
directory:
'/Users/rcline/grassdata/oakesModel/\ngridTest01sql'
Mapset Access fails because the mapset gridTest01sql begins with "\n".
This results because the g.mapsets -l returns multiple lines:
GRASS 6.4.0RC4 (oakesModel):~ > g.mapsets -l
aquiferBnd aquifers boresModel01 boresModel02 drains grid_tran01 grid_tran03
gridTest01sql oakes2 PERMANENT testAreaTopo
In lines 1800-1805 of preferences.py the call to g.mapsets -l is made on
line1800.
ret = gcmd.RunCommand('g.mapsets',
flags = 'l',
read = True)
mapsets =
if ret:
mapsets = ret.rstrip(' \n').split(' ')
In line 1805, ret.rstrip(' \n').split(' '), only the trailing line feed is
removed and not the line feed following the first line. Line 1805 should be
replaced with:
mapsets = ret.replace('\n','').split()
That way both the last line feed and any line feeds on multiple lines are
removed. Using .split() removes the need to handle the trailing space.
The change fixes the problem for me in 6.4RC4 and 6.4RC5. It also fixed a
crash when starting wxpython and opening an existing workspace. Can someone
with svn access verify my solution and fix this.
When invoking Mapset Access from the TclTK GUI, the search order was the
current mapset, Permanent, other mapsets in alphabetical order. With the
wxpython GUI, the search order is mapsets in alphabetical order. Was this
change intentional? It breaks some of my scripts, as I assumed that the
current mapset would always be searched first.
Royce Cline
GRASS GIS trac at osgeo.org
Mon Jun 8 11:27:42 EDT 2009
Previous message: [GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does
not work
Next message: [GRASS-dev] [GRASS GIS] #631: Discrepancies between tcl/tk and
wxpython PROJ_INFO files
Messages sorted by: [ date ] [ thread ] [ subject ] [ author ]
#630: "Mapset Access" broken (wxpython)
Reporter: cnielsen | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: normal | Milestone: 6.4.0
Component: wxGUI | Version: 6.4.0 RCs
Keywords: | Platform: MSWindows XP
Cpu: Unspecified |
!WinGrass Native binary 6.4.0svn 37703 on winxp-64Config->GIS Working Environment->Mapset Access returns this error message
(no dialog box appears):{{{
File "c:/GIS/GRASS-6-SVN/etc/wxpython/wxgui.py", line 373,
in OnMapsetsdlg = preferences.MapsetAccess(parent=self, id=wx.ID_ANY)
File "c:\GIS\GRASS-6-SVN\etc\wxpython\gui_modules\preferen
ces.py", line 1735, in __init__self.mapsetlb.LoadData(self.all_mapsets)
ces.py", line 1814, in LoadDatastat_info = os.stat(mapsetPath)
WindowsError
[Error 123] The filename, directory name, or volume label
syntax is incorrect:
'C:\\GIS\\GISDataBase\\spearfish60\\\user1'
}}}Note the double and, before the mapset, triple slashes.
Ticket URL: <http://trac.osgeo.org/grass/ticket/630>
