I think it's good - no complaints here.
~ Eric.
-----Original Message-----
To: Patton, Eric
Cc: 'Trevor Wiens '; 'grass-dev '
Sent: 9/23/2006 10:41 AM
Subject: RE: [GRASS-dev] grass63 -text startup screen
Hello Eric
On Thu, 31 Aug 2006, Patton, Eric wrote:
Paul,
I think your last text edit is the best one so far (from
http://grass.itc.it/pipermail/grass5/2006-August/025424.html) - and I
agree
with Trevor's idea to have the order changed to
Database/Location/Mapset to
reflect the true hierarchy.
OK here's a new version. I tried to make the database description more
general seeing it comes first. Really the user doesn't need to know that
locations are contained in the database directory, and mapsets are
contained in further directories below that - really just that all GRASS
data is stored in a particular place on the disk. Taking that point of
view makes it easier to describe what it is - more comments?
GRASS 6.3.cvs
DATABASE: A directory (folder) on disk to contain all GRASS maps and
data.
LOCATION: This is the name of a geographic location. It is defined by a
co-ordinate system and a rectangular boundary.
MAPSET: Each GRASS session runs under a particular MAPSET. This
consists of
a rectangular REGION and a set of maps. Every LOCATION
contains at
least a MAPSET called PERMANENT, which is readable by all
sessions.
The REGION defaults to the entire area of the chosen LOCATION.
You may change it later with the command: g.region
