RE: [GRASS-dev] invoking d.vect and d.rast from CLI
As a follow-up, I get the same behavior when I try to digitize with v.digit;
I am unable to render a raster or vector in x0 using the v.digit 'bgcmd'
parameter.
~ Eric.
-----Original Message-----
To: 'grassuser@grass.itc.it'
Cc: 'grass-dev@grass.itc.it'
Sent: 8/31/2006 2:15 PM
Subject: [GRASS-dev] invoking d.vect and d.rast from CLI
I'm having trouble getting d.rast and d.vect working on the command
line.
Here's a step-by-step to reproduce using Spearfish:
After initial Grass 6.3 startup finishes:
d.mon -L
name description status
PNG Create PNG Map not running
png1 Create PNG Map not running
png2 Create PNG Map not running
png3 Create PNG Map not running
png4 Create PNG Map not running
png5 Create PNG Map not running
png6 Create PNG Map not running
png7 Create PNG Map not running
gism Create PNG Map for gis.m not running
x0 X-windows graphics display not running
x1 X-windows graphics display not running
x2 X-windows graphics display not running
x3 X-windows graphics display not running
x4 X-windows graphics display not running
x5 X-windows graphics display not running
x6 X-windows graphics display not running
x7 X-windows graphics display not running
# Shouldn't gism be shown as running here?
d.mon start=gism
PNG: GRASS_TRUECOLOR status: FALSE
PNG: collecting to file: map.png,
     GRASS_WIDTH=640, GRASS_HEIGHT=480
Graphics driver [gism] started
~ >d.mon -L
gism Create PNG Map for gis.m running (selected)
# I seem to remember before that gism was shown as being selected
immediately
# upon starting Grass...
~ >g.region rast=elevation.10m
~ >d.rast -o map=elevation.10m
100%
# Nothing draws in the gis.m map display!
# Let's try a vector instead...
~ >g.region vect=soils
~ >d.vect soils
Again, nothing displays.
Any ideas on what's going on here?
~ Eric.
grass-dev mailing list
v.digit; I am unable to render a raster or vector in x0 using the
v.digit 'bgcmd' parameter.
in spearfish + GRASS 6.3-cvs (1 week old),
d.mon x0
v.digit -n tmp_map bgcmd="d.rast elevation.dem"
works fine for me.
Hamish
