RE: [GRASS-dev] Overlay grids and lines tool in gism fails to dra wgrid in map wi ndow
-----Original Message-----
To: Maciej Sieczka
Cc: Moritz Lennert; 'grass-dev@grass.itc.it'
Sent: 9/15/2006 1:44 AM
Subject: Re: [GRASS-dev] Overlay grids and lines tool in gism fails to
drawgrid in map wi ndow
Maciej Sieczka wrote:
>> d.grid segfaults for me too if I use RGB triplets for color or
>> bordercolor. If I use names (blue, red etc.) it works.
> Actually it works as long as the RGB values are 0 or 255. As soon as
> they are something else it segfaults.
Hmm, for me it segfaults whatever the values, eg.:
$ d.grid size=2000 origin=0,0 bordercolor=1:1:1
Segmentation fault
d.grid calls D_parse_color() before calling R_open_driver(), which
won't work unless the colour is one of the predefined colours
(D_parse_color() allocates the specified colour within the driver then
returns the index of the allocated colour).
Ok. But d.grid worked for me in late July using the default color settings
in gis.m (some kind of light grey), without having to first use a predefined
color. The manpage says that RGB triplets can be used. Is this no longer the
case then?
case then?
I see:
revision 2.5
date: 2006/04/18 05:19:49; author: cedric; state: Exp; lines: +6 -38
Added gisprompts for color. Uses simplified (abstracted) color handling. Removed colors.h header.
See diff here: http://freegis.org/cgi-bin/viewcvs.cgi/grass6/display/d.grid/main.c.diff?r1=2.4&r2=2.5
This might be the problem, although it happened in April...
Moritz
> case then?
I see:
revision 2.5
See diff here:
Revision 2.4 wouldn't have worked either. The R:G:B triplet would be
ignored, and d.grid would use the first available colour after the
predefined colours. Depending upon what you had been doing previously,
that colour *might* already be set to the R:G:B triplet you wanted.
The segfault is due to the recent changes to libraster. Before, any
R_* calls made prior to calling R_open_driver() would be silently
ignored; now, they'll result in a segfault.
