It uses scandir() to sort the directory entries alphabetically. I'm not
100% sure scandir can be found on all platforms in which case we need to
do something, like qsort() the names list instead.
not 100% sure scandir can be found on all platforms in which case we
need to do something, like qsort() the names list instead.
from the scandir(3) man page:
CONFORMING TO
None of these functions is in POSIX. LSB has deprecated the
library call alphasort() and never contained scandir().
The functions scandir() and alphasort() are from BSD 4.3, and
have been available under Linux since libc4. Libc4 and libc5 use
the more precise prototype
int alphasort(const struct dirent **a, const struct dirent **b);
but glibc 2.0 returns to the imprecise BSD prototype.
The function versionsort() is a GNU extension, available since
glibc 2.1. Since glibc 2.1, alphasort() calls strcoll(3); ear-
lier it used strcmp(3).
CONFORMING TO
.. a POSIX compliant solution would be nice,
My man says:
CONFORMING TO
None of these functions is in POSIX.1-2001, but alphasort() and
scandir() are under consideration for a future revision to
POSIX.1.
So would that satisfy you? Or do you perhaps prefer Daniel's patch, which is perhaps better. Mine is more like a quikfix...
FWIW, Linux and OSX have it. Googling around it seems that Solaris 10
has it, but older Solaris/SunOS versions don't seem to. Ditto for IRIX
and, of course Win32.
Daniel.
CONFORMING TO
I am not very good with pointers, but shouldn't there be a G_malloc()
somewhere if G_free() is used?
scandir does the allocation.
or another way: should we keep malloc()+free() separate from
G_malloc()+G_free()? ie don't mix the two?
Isn't G_free just a wrapper for free, so that programmers don't need to worry about linking with correct allocation libraries, and including headers which vary on some UNIX platforms?
Well that kind of does make the decision for us, since we want GRASS to be able to compile natively on Win32, right?
According to the programmers manual:
"The following routines provide memory allocation capability. They are simply calls to the UNIX suite of memory allocation routines malloc( ), realloc( ) and calloc( ), except that if ther is not enough memory, they print a diagnostic message to that effect and then call exit( ).
Note. Use the G_free( ) routine to release memory allocated by these routines."
So in practice they are the same, but I think it is cleaner programming and safer in the long run not to mix malloc() with G_free() etc.
> CONFORMING TO
My man says:
CONFORMING TO
POSIX.1.
Not me; use opendir/readdir/closedir + qsort instead.
MinGW provides implementations of these functions on Windows, or you
can use the native functions FindFirstFile, FindNextFile and FindClose
instead.
