Otto,
I've just been starting at the oldest bugs and working my way forward. I've
noticed a lot of the older bugs I've encountered aren't relevant anymore as
the source code has improved and changed so much over the last 3-4 years.
~ Eric.
-----Original Message-----
To: grass-dev@grass.itc.it
Sent: 8/3/2006 4:58 AM
Subject: Re: [GRASS-dev] Re: GRASS bugs
Am Mittwoch, 2. August 2006 19:15 schrieb Maciej Sieczka:
Glynn Clements napisa?(a):
> Moritz Lennert wrote:
>>> But generally: why wait for a bugfix party? Just go ahead...
>> I don't think it is about waiting, it is about creating a special,
>> motivating event where everyone works together on one goal.
> The one thing which would do the most to motivate me to fix bugs
would
> be a list of clearly-identified, verified, reproducible bugs.
I can do that and will send it to the list. Most likely next week. If
there is no obvious test case I will try to create it based on
spearfish.
To all you Guys who were willing to help with testing during the bug
sqaushing party: please give me a hand with that. Each of you, pick
few
reports, verify it using spearfish, or, for bugs in the interface
etc.,
just verify if it is still present in current CVS. Then 'reply' from
the
tracker CCing me at my email. You can do it all even as guest, just
make
sure you sign with name and email. If I counted OK there should be 5
testers alltogether. Such a band can clean the mess up easily. Anybody
please join!
would it make sense to create a list of bug IDs to verify - maybe in
wiki?
People can add themselves together with their favorite IDs to make sure
that
bugs won't be verified twice.
regards,
Otto
> Back when I used to check the RT occasionally, I would generally
skip
> any report where I couldn't quickly reproduce the problem from the
> information contained in the report.I agree this is often the case that people don't document their
reports
well enough, but this doesn't mean such reports should be ignored
completely.> As this tends to be the case for the vast majority of reports, I
> eventually gave up checking the RT altogether
> (other than to kill requests generated by spam email to the
grass-bugs
> address).
Please don't waste your time. This is such an easy task I can do it
myself (and I'm doing it).> If people want a bug to get fixed, by far the most important factor
is
> providing a clear mechanism to demonstrate the bug, either using the
> spearfish dataset or starting from a new location (i.e. using
> self-generated test data).I know, I've failed to do it often too. But I also reported bugs, and
saw other's reports, documented well but still never taken care of.You are right there is a need to clean up the tracker further to make
developers' work easier. I'll work on this as I can.Maciek
grass-dev mailing list
