RE: [GRASS-dev] Re: [STATSGRASS] r.in.xyz: New module for loading and binning massive x, y, z datasets (LIDAR, Swath bathymetry)
Hamish,
Thanks for this script! It's MUCH better than the hack I was using (i.e.,
xyz --> GMT's xyz2grd --> r.in.bin). I can confirm the program worked
perfectly with a 980MB swath multibeam bathymetry dataset.
Eric Patton
epatton@nrcan.gc.ca
-----Original Message-----
From: grass-dev-bounces@grass.itc.it [mailto:grass-dev-bounces@grass.itc.it]
Sent: Monday, June 12, 2006 12:48 PM
To: Hamish
Cc: grassuser@grass.itc.it; statsgrass@grass.itc.it; grass-dev@grass.itc.it
Subject: [GRASS-dev] Re: [STATSGRASS] r.in.xyz: New module for loading and
Hamish,
I think this is a wonderful and much needed addition. Thank you very much!
Tom
Hamish wrote:
In blatant violation of any sort of feature freeze for the next
release of GRASS GIS I have added a new (long missing) module to GRASS
6.1:
  r.in.xyz
This is a replacement for s.in.ascii+ s.cellstats+ s.to.rast in GRASS 5.
The r.in.xyz module will load and bin ungridded x,y,z ASCII data into
a new raster map. The user may choose from a variety of statistical
methods in creating the new raster.
r.in.xyz is designed for processing massive point cloud datasets, for
example raw LIDAR or sidescan sonar swath data.
And it's fast. Very fast.
idea:
  http://grass.itc.it/pipermail/grass-dev/2006-May/023376.html
help page:
  http://grass.ibiblio.org/grass61/manuals/html61_user/r.in.xyz.html
screenshots:
  http://hamish.bowman.googlepages.com/grassfiles#xyz
The r.to.vect module has been given a "-b" flag to skip building
vector topology (same as v.in.ascii) and the v.surf.rst interpolation
module has been modified to not require topology from input points.
This gets around the approx 3 million point memory limit of the vector
engine due to topology overhead. [i.e. you can fill holes with
regularized splines]
question for stats experts: Should it be using population or sample
variance? n is generally low so it makes a difference here. In
r.univar it is usually so large not to matter (there we use population
variance for vague reasons).
Thanks to Helena Mitasova for testing and helping me work out the last
few bugs. I would be interested to hear how things go with Large input
files (LFS, bigger than 2gb).
enjoy,
Hamish
statsgrass mailing list
http://grass.itc.it/mailman/listinfo/statsgrass
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams@noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
grass-dev mailing list
