RE: [GRASS-user] Adding a semi-transparent layer
Thanks, Len.
Usually is very interesting to know that there's more than one way to do
something. I will have in mind your approach.
José A. Ruiz Arias
Departamento de Física
Escuela Politécnica Superior
Edificio A-3, Campus Lagunillas
Universidad de Jaén
23071 Jaén Spain
Tlf. +34 953212474
Email: jararias@ujaen.es
_____________________________________
-----Mensaje original-----
De: Len Coop [mailto:coopl@science.oregonstate.edu]
Enviado el: jueves, 22 de marzo de 2007 19:35
Para: José Antonio Ruiz Arias
Asunto: Re: [GRASS-user] Adding a semi-transparent layer
Jose,
Now that you have a solution I send you a very simple one using ppmmix:
#!/bin/sh
# example use of ppmmix - blend climate data layer (based on humidity)
with shade relief
main=SNC_V2
sublayer=dem90m.nw.sh.bal
opacity=0.65
r.out.ppm $main
r.out.ppm $sublayer
/usr/bin/ppmmix $opacity $main.ppm $sublayer.ppm | pnmtopng >
orig layer is at http://pnwpest.org/snc/SNC_V2.png
blended layer is at http://pnwpest.org/snc/SNC_V2.mix.png
Len
José Antonio Ruiz Arias wrote:
> Seems to work fine. Thanks a lot Glynn. :wink:
> José A. Ruiz Arias
> Universidad de Jaén
> 23071 Jaén Spain
> Tlf. +34 953212474
>> De: Glynn Clements [mailto:glynn@gclements.plus.com]
>> Enviado el: jueves, 22 de marzo de 2007 15:19
>> CC: grassuser@grass.itc.it
>> Asunto: RE: [GRASS-user] Adding a semi-transparent layer
>>> I've been trying to create the PPM/PGM pair with the PNG driver. Using
>> the next commands I get the ppm file:
>>> export GRASS_TRUECOLOR="TRUE"
>>> export GRASS_WIDTH=642
>>> export GRASS_WIDTH=371
>>> export GRASS_PNGFILE=mde.ppm
>>> d.mon start=PNG
>>> d.mon select=PNG
>>> d.rast map=mde
>>> d.mon stop=PNG
>>> But doing the same for the pgm file I get an error message. I have
>>> looked for some specific command in GRASS to create de pgm but I
>>> haven't found it.
>> Add:
>> export GRASS_TRANSPARENT=TRUE
>> This will cause a PGM file to be written out in addition to the PPM
>> file. The PGM file contains the mask.
>>> Also looked for the mapdisp.tcl to take it a look
>>> but I don't have it in my system (at least that's what I think).
>> The file which performs the compositing is etc/gm/mapcanvas.tcl.
>> Glynn Clements <glynn@gclements.plus.com>
>> __________ Información de NOD32 2134 (20070322) __________
>> Este mensaje ha sido analizado con NOD32 antivirus system
>> http://www.nod32.com
> grassuser mailing list
> http://grass.itc.it/mailman/listinfo/grassuser
Dr. Leonard Coop
Assis. Prof. (Research), Dept Botany & Plant Pathology
Integrated Plant Protection Center
2040 Cordley
Oregon State University
Corvallis OR 97331-2907
Phone 541-737-5523
http://pnwpest.org/coopl
__________ Información de NOD32 2136 (20070322) __________
